AE "steps/pops"? at DVinfo.net
Old November 24th, 2008, 10:02 AM   #1
AE "steps/pops"?
I've been shooting my XH-A1 primarily with AGC turned off. My thinking is that it lets me have more control over noise. I also often shoot with the camera in Auto recording mode. I started noticing that when the camera changes the exposure, instead of a smooth transition it changes abruptly and looks poor on tape etc. After some experimentation I found that allowing the camera to do AGC stops this behavior. I have "AE Response" already set to "Low".
Does this make sense? Thoughts? Suggestions?
-- Larry Chapman
Larry Chapman is offline   Reply With Quote
Old November 24th, 2008, 12:14 PM   #2
Yeah... actually it does. I shoot motor racing from late afternoon to night from high atop the sky boxes at the track. I've noticed this stair-stepping exposure at night when zooming out from a tight shot. Since the lights at the track are not all that bright I' running wide open at 1/60 with +6db gain.
Although I don't understand the specifics, I have learned that the more the lens is zoomed in, the smaller the maximum iris opening. Since I shoot in AE mode, and some of the extreme tight shots are under-lit, when I zoom out the iris wants to open more. Canon apparently did not design well for this use case.
Just so you know, I used to shoot full manual but AE is much faster than I am, and I experienced the problem with that setting too. I know. That seems to subvert my contention but I would set the iris when not fully zoomed so when going in tight, the iris would open up. No joy either way.
I suspect that auto gain acts as a bit of an exposure "shock absorber", if you follow my analogy. Auto gain can react more quickly than the iris so it compensates as the iris changes. Since I shoot in the dark, your remedy will not work for me because I'd end up with more grain than a dairy farmer.
Tripp Woelfel is offline   Reply
