Import problem with Premiere Pro CS3 at DVinfo.net
Old November 6th, 2008, 10:16 PM   #1
Hey guys,
I'm trying to import a piece of footage that I filmed, its about 60mins long, and I captured it as a whole clip. The audio however looses track for some reason and about 20mins in, the audio just about starts from the begining, but the video stays the same. I checked the raw video I captured in a media player and the original tape playback and it is fine all the way through. But when ever imported into Premiere, the sound is way off...
I also did this with several other clips in the same project and all turned out well, its just this rogue clip...
Any Clues as to why this may have happened??
Jeremy Nemeth is offline   Reply With Quote
Old November 7th, 2008, 12:15 AM   #2
very common hdv issue with cs3, look up and use HDVSPLIT to capture, it'l solve your problems and gives you the option of scene detection too. best part is it's free.
Dany Badaoui is offline   Reply With Quote
Old November 7th, 2008, 06:38 PM   #3
Hey Dany,
Thanks for the tip! That helped out a ton! that program is pretty nifty, every thing came out fine.
Thanks again!
Happy Filming!!
