Thread Tools
Search this Thread
Console sw does not recognize XHA1 in Vista
I just downloaded a trial version of the Console software on my laptop that has Vista Home Premium.
The operating system recognizes the camera on firewire and installs the XH A1 driver ok. But when I launch the console software, it still cannot recognize the camcorder. Is this a quirk of Vista? Has anyone run into this and solved it? I tried the same experiment with another laptop I have with XP on it, and it worked fine and the trial version of Canon Console software able to recognize the XH A1 over firewire. |
Contributor
I'd get rid of Vista and install XP on the laptop.
Not to sound rude, but isn't that a bit like throwing your car away because the ash tray is full?
It seems the XP/Vista debate is approaching the proportions of the old Mac/PC scrum. There are many who live quite happily with Vista, and others who've had nothing but grief with it. Vista is what's now and XP will shortly shuffle off to the land of the unsupported. But wait... Shailesh is having a problem with a software trial. Not sure he wants to redo his entire system just for that. Shailesh... you might want to uninstall the Console software and re-install it. That will sometimes clean up wonky software. You might also want to check the support site for Console for any read-mes, FAQs and other data that might help you. I haven't seen too much about Console here. |
Shailesh,
I would try 1. Set the Console program to run in Windows XP compatability mode. 2. Rerun the program - does it now work? Let us know the results, good or bad. Shouldn't take long to try! |
#5 |
Contributor
Didn't mean to insult anybody, I assumed it would be fairly easy to install the other OS since he has two systems already and it works fine with XP. If he installs XP in the laptop and everything works, that would show it's Vista, but if it didn't work, then there's some other problem.
#6 |
All,
Thanks for your feedback and mindshare in this matter. Yes I did uninstall and reinstall the software. I tried different combinations of starting console first then the camera and vice versa etc, to no avail. Then I sent an email to Canon support asking for support on the console sw for Vista and the replied back saying the Console Software is not supported on Vista. I guess that sums it up for me. Shailesh |
#7 |
Wondering if we might get reports from anyone who actually HAS had success running the current version of Console on a Vista machine?
Are any special steps like XP compatibility mode needed to get it to run? At this point in time where you really have to go out of your way to have XP rather than Vista on a new laptop, I'd have to say it would be unsatisfactory for such expensive software not to be updated to run on Vista. If it turns out that this is more than a specific issue with Shailesh's computer and Console really doesn't run properly on Vista, even in XP Compatibility Mode, I'll have to admit to being a bit disappointed and surprised. See: http://www.dvinfo.net/conf/676103-post5.html The only Vista machine I have access to at the moment is my daughter's laptop. If I have time and can get my hands on the computer, I'll try installing Console on it and see if it recognizes my XL cameras.
Pete Bauer The most beautiful thing we can experience is the mysterious. It is the source of all true art and science. Albert Einstein Trying to solve a DV mystery? You may find the answer behind the SEARCH function ... or be able to join a discussion already in progress! |
