The ultimate preset. - Page 2 at DVinfo.net
Old November 8th, 2008, 08:12 PM   #16
25fps PAL = 24fps NTSC ???
Billy Griffin is offline   Reply With Quote
Old November 23rd, 2008, 09:10 AM   #17
well it does not = 24fps, but it is the equivalent ; ).
thanks Giovanni, I'm going to try this out today.
JS
John Stakes is offline   Reply With Quote
Old November 24th, 2008, 09:43 AM   #18
JS
Actually I guess NTSC's 30fps would be the equivalent to PAL's 25fps when speaking of standard frame rates...my bad
Old November 26th, 2008, 06:08 PM   #19
Is there a way you could post the custom preset file on this forum? It would be immensely appreciated.
Guiseppe Palumbo is a talentless scam artist -- avoid him at all cost.
Travis Hart is offline   Reply With Quote
Old November 27th, 2008, 08:44 AM   #20
Perhabs this one :
File Type: cpf VISION03.CPF (40 Bytes, 534 views)
Canon XH-a1 user & Edius NX Canopus
Arnold Tersteeg is offline   Reply With Quote
Old November 27th, 2008, 05:25 PM   #21
Thank you kindly, mate.
Old November 29th, 2008, 06:05 AM   #22
YW Travis (Y)
Old December 2nd, 2008, 10:04 AM   #23
I will be trying this out for my paintball tutorials. If I can remove levels correction from my workflow it will definitely speed up render time.
Thank You!
Kevin | www.kraentertainment.com
A picture is worth 1,000 words | A 2 hour film at 24fps is worth 172,800,000 words
Kevin Amundson is offline   Reply With Quote
Old December 2nd, 2008, 06:55 PM   #24
Presets
Is there a way to have the preset name appear as opposed to the number...for instance Vision2 instead of CP1...I only want to have 2 presets available..I'm not always sure which preset I'm using. thanks
Michael Grayson is offline   Reply With Quote
Old December 2nd, 2008, 07:41 PM   #25
No, you can't unfortunately :(.
Randy Panado is offline   Reply With Quote
Old December 2nd, 2008, 09:33 PM   #26
as far as i know, the updated XH-A1s will display the preset name on the lcd screen
Chris Light is offline   Reply With Quote
Old December 2nd, 2008, 10:14 PM   #27
Hopefully us XH-A1 users get some sort of firmware upgrade to do so also! But don't see it happening....
Old December 2nd, 2008, 10:47 PM   #28
Have 2 presets named CP1 and CP2 and go back and forth.
You can manually change one of the custom keys to reverse the preset button.
JJ
J.J. Kim is offline   Reply With Quote
Old December 6th, 2008, 03:56 PM   #29
I'm having trouble installing it!
I downloaded it and placed it in the folder none as Presets.
But it doesnt show up on the camera!
help
thanks!
Wayne Smith III is offline   Reply With Quote
Old December 6th, 2008, 06:03 PM   #30
The folder name is PRESET not Presets. Singular. Made the same mistake myself the first time.
Marcel D. Van Someren is offline   Reply
