is my shutter speed to high or is it another problem? at DVinfo.net
Old August 28th, 2008, 04:09 PM   #1
A Weekend in Wales on Vimeo
i shoot at quite a high shutter speed (around 500)
not sure if you will see it watching directly from vimeo, you may have to down load it
when the waves are rolling they seem a bit jerky but the riders look smooth to me (about 1:55 is an obvious example)
whats your opinion/advise
thanks
Kev O'Brien is offline   Reply With Quote
Old August 28th, 2008, 07:40 PM   #2
Contributor
Any time you shoot at a higher or lower than normal shutter speed you start to get some strangeness. At a shutter speed that high my guess is that's definitely the problem. If you have a desktop or window fan where you can see the blades moving, set up your camera and start cranking the shutter speeds faster and faster and you'll easily see the problem. Eventually you can even get the blades to appear to turn backward.
Old August 28th, 2008, 09:51 PM   #3
As a general rule if your shooting 50i which I presume you are stick the shutter on 1/50 for a normal look. I sometimes will drop to 1/25 in lowlight instead of pumping up the gain.
If you want different effects then play around with it,
Jonathan Shaw is offline   Reply With Quote
Old August 29th, 2008, 10:41 AM   #4
thanks for the replys, i tend to shoot higher shutter speeds due to the fast moving nature of the sport, on lower shutters i find i get alot of blurriness around the riders in the middle of tricks and it becomes quite noticable in slow mo, also i find the water spray looses its crispness
if that is my problem i will try it lower around the 250 mark and see if that helps but 50 is not quite fast enough from previous experience
ive always wondered why they make them to go so high if everyone shoots at 50 /60
i think my a1 goes to around the 4000 mark
Old August 29th, 2008, 11:01 AM   #5
High Speed Shutter is a feature they can add to relatively easily and for some shots can be quite effective. If the quality of the image in slow mo is the priority then the higher shutter speeds are the way to go. Played at normal speeds the short exposure time of the shutter means the usually blur of the longer exposures times of the regular shutter speed doesn't exist and the footage stutters to your eye since you are seeing a sharper group of stills with a longer gap of motion between frames.
Old August 29th, 2008, 02:58 PM   #6
Kev... I think for what you are doing 1/500 is not too fast. In looking at action sport on TV I notice that they often use a fast shutter. Not certain of their rationale, but I do it when I shoot motor races to keep the foreground and background as crisp as possible. Whip pans following a car could decimate the background with a slow shutter speed.
A faster shutter will give you cleaner slomo options, which is something used several times in your referenced clip. Going to 1/250 shouldn't make much of a difference there.
While there are rules, you have lots of options based upon your personal preferences. You get to pick the look you like. If you don't like the choppiness of 1/500, play around with all sorts of different settings to find out what works best for you.
BTW... As a former ravenous windsurfer I feel cheated that I was born too early for kiteboarding. It looks like a real hoot. Unfortunately a hip replacement put an end to my sailing.
Tripp Woelfel is offline   Reply
