FCP/XH A1 setup for viewing HDV on TV? at DVinfo.net
Old August 27th, 2008, 06:46 AM   #1
Hiya.
How do I setup Final Cut Pro and the XH A1 to view my HDV sequence on an ordinary TV (as a monitor). I've been scouring the menus and whatever I can find on the forums, and I haven't been able to get it working yet...
At the moment I've got the camera plugged in via firewire, and the component out on the camera connected to the TV. I presume the camera should be on play and FCP on 'External Video: All Frames' and 'Video Playback: HDV 25p' but that last option is grayed out.
Help much appreciated... thanks, Ian
I'm on FCP 5.1.4, by the way.
Ian Henderson is offline   Reply With Quote
Old August 28th, 2008, 01:02 AM   #2
I've read somewhere that you can't pass HDV back out through firewire to view on the camera from FCP. Is that true? I had this working with DV...
Old August 28th, 2008, 06:03 AM   #3
You can't preview HDV to an external monitor in realtime over Firewire, not like you can with DV. You need a hardware solution such as the AJA Kona LHe card to do this.
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply
