Can you get a better zoom lens for the A1 ? at DVinfo.net
Old August 13th, 2008, 03:09 PM   #1
Are there any new lens` you can buy for this camcorder with better zoom facility ?
Jayson Corcoran is offline   Reply With Quote
Old August 13th, 2008, 03:13 PM   #2
there are add on lenses such as telephoto or wide angle lenses which attach to the stock lens but you cannot replace the stock lens on the a1 or the g1.
Rob Stoner is offline   Reply With Quote
Old August 13th, 2008, 03:30 PM   #3
Rob has given you the answer already, but a 20x ratio zoom lens with the quality of the XH-A1's is actually pretty good going as it is. Once you get much above that range, there are some pretty serious compromises in an affordable lens. Anyway, when using a significantly longer focal length, you start getting into problems with tripods (they have to be VERY good) and nae chance of a handheld shot.
If you search dvinfo you will doubtless find threads on telephoto adaptors for the XH-A1. I've only got the Canon wide angle (and the muscles to prove it).
Colin McDonald is offline   Reply
