#16 |
In My everyday use HV30 I have used nothing but Sony HDV tapes, bought in a 5 pack now these are less then 10 bucks each- never had a single drop out yet. I don't consider this to be an unreasonable cost at all.
My A1 has never seen any other tape but canon's hdv tape, and while expensive so is the Camera you are shooting with , I buy them by the case lot to reduce the overall net cost per tape, but agreed even buying them this way they are still one of the most expensive options. I figure the extra cost is just the price of doing business & Charge accordingly. Ive never had a single dropout using the canon either. If I were using this camera as a fun shooter I might consider a cheaper option ,But as a working camera I can't afford to possibly have to reshoot something because of a problem even if that is possible, and in most cases its not an option. And Nobody involved is ever happy about having to do a reshoot . Also if there ever is an issue I won't feel at all bad about bitching at Canon and saying hey look this camera's never run anything but your tapes in it ever. |
#17 | |
What tapes do you use in your XHA1 please Tom? Am on the verge of buying a bulk-load of tapes and want to be safe and sound :o) EDIT: If you don't use a XHA1 ignore this, sorry Last edited by Peter Dunphy; September 8th, 2008 at 07:25 PM. |
#18 | |
Valuable advice. I guess I should try a single tape in a test before committing to a bulk purchase? |
#19 |
Buying just one tape and then testing it and going back for more will undoubtedly take you to another batch even if the brand's the same so the experimental results will be inconclusive and unreliable.
First thing is to choose a tape and stick with it. Buy 50 or 60 Sony Premiums (or whatever you choose) and get a head cleaning tape at the same time. There’s still an impression out there that used tapes are somehow inferior to new ones. I’m still wary of the fact that one hour MiniDV tapes can be bought for little over a pound a piece, and as 17.5% of that is tax, they can’t cost much to begin with. Being so cheap suggests that there’s some pretty expensive highly automated machinery at work, and that there’s precious little in the way of human inspection being carried out. Which is why I say that if you’ve used a tape and know it to be good, that’s the same as using your microphone and knowing it to be good. So I’m not afraid to reuse my tapes over and over again, and these days they’re being put to quite a test – recording HDV. But as I say, there’s still a hard core of people who equate used tape to mean inferior tape, and they tend to work under the impression that as it’s so cheap, then you should always use new. In fact tape is probably at it smoothest and best after it’s been burnished by the spinning heads a couple of times, that will have knocked off all the high spots and imperfections. It's odd that most people instinctively think of re-recording a tape as "re-using" it but see no likely problem with playing it back repeatedly -- or even running it back and forth over the heads for log-and-capture. It’s all tape re-use. For really important projects I would push the boat out and step up a notch from the everyday Premium grade to the Sony Excellence, the professional grade DVCAM or tape labelled for HDV. Many claim there is no difference between grades, but I’m a firm believer in that you get what you pay for, and more expensive tape will have been slit from the centre of the wide ribbon and may well have had further polishing operations to ensure the lowest possible dropout levels. For HDV this is really important, as the same dropout will affect far more frames than if you had been shooting in standard definition. tom. |
#20 |
Tom - from my point-of-view, I almost never reuse a tape because I almost never want to loose what I recorded the first time. It's my archive. For example, I've just finished editing two new programmes using stuff I shot on S-VHS in 1997 and 1998, and I've got more going back to 1990 that hasn't seen the light of day yet.
If it weren't for that, I'd agree with you - up to a point. There must be a point when the tape starts to wear and becomes as much of a risk as an unknown new one. Ideally, you'd want to stop recording to it while there's still, say, 10% of its life left, so that you can still play it back a few times. How many times do you reuse a tape? 10? 100? 1000?
Steam Age Pictures - videos in aid of railway preservation societies. |
#21 |
Somewhere between 10 and 100, but I keep no check - only a huge pile of them. But I do keep my tape paths spotless and load and unload as if I was in an operating theatre.
#22 |
I decided to go with the Panasonic DVM63AMQ, but also have a need for other, less expensive tapes. It's my understanding that it's ok to use different quality tapes as long as I stick to the same manufacturer?
If so, should I use a tape head cleaner between switching products (manufactured by the same company), or is that unnecessary? |
#23 |
I would say yes, stick to products from the same manufacturer and you won't go far wrong. Head cleaning between tapes will then not be needed.
#24 |
The biggest issue with tapes is to consistently use one brand and model. never, ever, use other tapes with your camera's heads.
the problem is with lubrication, every tape manufacturer has different kinds. Sony being the most serious offender using wet lube. I use DVM63PQ, and I buy them in bulk, 50-150 tapes at a time. It brings the cost down to be comparable w/ Costco's TDKs. I really don't think you need DVM63AMQs at all. The PQs are just fine and they're also cheaper in bulk. For the most part, never, ever, use a head cleaner, and also, never ever reuse a tape for recording. Head cleaning tapes will sandpaper off dirt, grime, and grease.. so use only and ONLY when you have dropouts. As for switching tapes, even models introduces your heads to different conditions that can create more crap causing my dropouts. Pick a tape and stick with it is my choice. |
#25 | |||||
I've owned a Sony HC1 since April 2006 and have mainly used the Sony DVC-60 PR/5 Premium Minidv Videocassette ( 5DVM60PRL ) which I always got cheap for under $3. I've never had a problem. Since I still plan to keep my HC1, it would be nice to be able to share the same tape. And even though it seems it can be done (from the PRO-TAPE site given out in this thread): Quote:
But I'd like to at least use cheaper Panasonic tapes for non-important projects. I'm thinking between the PQs in Peter's Panasonic Summary (below) or even the EJs (not listed in Peter's summary). The PQs can be had for around $3.50ish it seems and the EJs can be had for $2.50ish. Quote:
Current Audio Equipment: two AT822 mics, Sony MZ-RH1, and KE-110CCR. What else should I get for short films and recording stand-up comedy? http://is.gd/kePy |
#26 | |
I decided to go with the PQs for now and grabbed a 10 pack from Amazon. I'm debating on getting at least a few AMQs to keep handy for really important recordings, but will probably place that order a little later.
#27 |
Second post on tape topic
In the past 5 years I used cheap Costco TDK's and never once had a drop out in hundreds of tapes. When I purchased my first XH-A1 I changed to using Panasonic AY-DVM63PQ. My first batch was okay but I have had drop outs from my next two purchased batches.
What we tape is too valuable to rely on poorly made media. |
#28 |
You know, I went into this thread after a search for 'best tape' for the first time thinking, "superb, two pages of messages, I'm bound to have the brand and make to choose after reading this lot"
Here I am now at the end of the thread, and I'm more confused than when I started! Here's to mixed opinions! To summarise, it would seem the two main contenders are Sony or Panasonic. Panasonic have dry lube, Sony is wet, I shouldn't mix the brands. Some say the wet lube on the Sony can make the head life shorter, whilst the Panasonic are apparently guilty of severe dropout (PQ grade). Heck, you guys sure make it difficult for a guy to choose what he should get!! :-) |
#29 |
There's no 'best tape' Chris. Choose a brand and stick to it. They're all good. The more expensive tapes *might* give you less dropout, but they don't come with a guarantee.
I really rate Sony Premiums. Cheap, plentiful, good. |
#30 |
Thanks Tom. I'm mindful that any possibility of dropout could be expensive for me. I'm gathering the equipment I need for a higher-budget short. I'd rather spend the money than lose the shot, especially with relatively inexpensive equipment like tapes. As I hear you say numerous times in other posts, you're a great believer in you get what you pay for!
That said, I don't want to unnecessarily waste money if it really doesn't make a difference what tape to use. Am I spending too much time debating this issue I wonder?! Chris PS. Good website with excellent explanations about the differences across brands and grades: Tape Resources - MINI DV vs DVCAM, Tape Cleaner, DV Head Cleaning, Care and Handling |
