XH Custom Presets Download Library (copy) - Page 10 at DVinfo.net
Old June 24th, 2007, 02:30 PM   #136
Some of the presets from the DVInfo library are raising some questions for me.
"AC PREF1" - Who is Alister Chapman and what about his preferred settings make them good for everyone else?
"5248FILM", "5296FILM" - What about these film stocks makes them discernable? I mean, what films or scenes have a look characteristic of these stocks?
"AVGFILM" - Define the "average" film stock.
"TERRA1" - Described as a "soft" image. Is this the kind of look one could use for a vintage look, or for something more surreal? (Such as the restroom scene in Casino Royale when Bond is poisoned. Could that be done with a preset, or would a lens filter be the way to go on that one? Kind of looks like AfterEffects to me.)
I apologize if any of this sounds trivial.
Blake Burress is offline
Old June 24th, 2007, 02:45 PM   #137
Doesn't sound trivial; just sounds like you haven't done your homework. As I've explained here many times before, these presets are *translations* of existing XL H1 presets (and very rough translations at that).
Alister Chapman is a DV Info Net regular and an XL H1 owner who created a series of XL H1 presets for his own personal use, and graciously chose to share them with his fellow DV Info Net members. As to what he meant by "average" film stock, or for that matter any of his other presets, you're better off asking him directly. You'll find him in our XL H1 forum.
Same thing for the author of the Terra 1 and 2 presets -- Luis de la Cerda has an entire thread dedicated to those presets, it's located at http://www.dvinfo.net/conf/showthread.php?t=66581
The whole point of sharing these roughly translated XL H1 presets with the XH crowd is just to give a little idea of what's possible through some experimentation. They were never intended to be anything more than that. If you're thinking, what should I use these for, then the answer is that you shouldn't be using them for anything because they were never created for the XH camcorders to begin with.
They're intended only to motivate XH owners to create their *own* custom presets.
Hope this helps,
Chris Hurd is offline
Old June 24th, 2007, 02:49 PM   #138
An even better answer than I had hoped for. Thanks, Chris.
Old June 26th, 2007, 09:03 AM   #139
I've been using the presets on my A1 with great results, as I think others on the boards have been doing. Is that bad, or am I just too lazy to make my own?
www.eidolonfilms.com
Ben Crosbie is offline
Old June 26th, 2007, 09:19 AM   #140
Nothing wrong with that, Ben -- those three included presets were put there for a reason!
Old June 26th, 2007, 10:53 AM   #141
I didn't have any trouble getting the 18 initial presets onto my SD card a few months ago, but I put PRESET25 (VIVIDRGB) on there today (in the PRESET folder) and it's not showing up in my camera. They still just go to 18. Did I do something wrong?
Old June 26th, 2007, 10:56 AM   #142
Valid preset names go from PRESET01.CPF on up to PRESET20.CPF so you need to re-name that file.
Old June 26th, 2007, 11:52 AM   #143
So is there any way to open Excel and dial in a preset, and then save it as a .CPF and put it on my SD card? I haven't been able to find a thread that describes this process yet.
EDIT: Disregard that. I'm using XHTuner instead.
Old June 27th, 2007, 02:31 PM   #144
Bleach Bypass Preset
Hey there,
So after a couple of requests, here is a CPF file of my bleach bypass preset, called simply "BleachBP".
In case you can't read CPF files, I'm also including the settings in Excel format and a link to the original post.
http://www.dvinfo.net/conf/showthread.php?t=86026
Enjoy.
File Type: cpf PRESET04.CPF (40 Bytes, 980 views)
Juan Diaz is offline
Old June 27th, 2007, 09:06 PM   #145
HC1 settings
Originally Posted by Jerome Cloninger View Post
Revisions of my two presets if anyone cares...
JCDVday1 - Matches the color of my Sony HC1 cameras. Tweaked from the old one I posted a while back. Now its good in low light with addition of camera light or stage lights.
www.jcdv.com/PRESET/PRESET02.CPF
JCDVlow1 - My best attempt at a really low light preset. I have to tweak some in post such as contrast, levels and/or some saturation... but its a good base. I constructed this in a room with only a computer monitor with white background (like dvinfo site) as the only light source.
www.jcdv.com/PRESET/PRESET03.CPF
Hi Jerome.
Thanks for sharing HC1 preset(JCDVday) and I used it indoor, good skin tone comparable to my PD170, outdoor I haven't tried. For your HC1 settings(color, contrast etc), can you share me those for my friend's HC1? We're planning to shoot short film using both cameras.
Nathan
Nathan Supan is offline
Old June 27th, 2007, 09:17 PM   #146
Originally Posted by Nathan Supan View Post
Hi Jerome.
Nathan
No problem... on the HC1, set the camera color to +2 and sharpness to +2...
Jerome
www.jeromecloninger.com
Jerome Cloninger is offline
Old July 9th, 2007, 01:42 PM   #147
Presets for low light
I currently film hunting videos and as the light changes from high to low light or vise-versa I would like to have presets that would make it easier for my wife to push so her video stays corrected. Does anyone have presets that would make this easier for her to use the camera with less adjusting? I would really appreciate any help here.
Steve Porchet is offline
Old July 17th, 2007, 07:44 PM   #148
Steven,
On your VividRGB preset you use the Cine 1 gama and on the Panalook, Cine 2. Should the frame rate for the camera be set at 30f and 24 respectively when using these presets?
James
James Lynch is offline
Old July 17th, 2007, 08:11 PM   #149
Disjecta
James, the frame rate has no influence on the preset. It is only changing the "look", not the cadence.
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline
Old July 17th, 2007, 08:19 PM   #150
Wow! That was a fast answer! I appreciate your advice and your wonderful "leadership" in the area of presets. Also, congratulations on the beautiful movies on your site - now I have someting to shoot for.... Thanks.
