Canon a1 and hv30 at DVinfo.net
Old July 18th, 2008, 04:42 PM   #1
Canon a1 and hv30
I just received my hv30. I will be shooting an interview Monday and would like to use the HV30 as B camera for a static wide shot while using my A1 for close up.
Any recommendation on what preset or strategy to match them.
I am editing on FCE 3,5 and my MBP is my only monitor.
Measure twice, cut once!
Robert Morane is offline   Reply With Quote
Old July 18th, 2008, 06:54 PM   #2
Robert... I do something vaguely similar, but it's to cover racing. The A1's companion is an HV10, which by everything I've read works very similarly to the HV30. I shoot with the default A1 setting for fear that anything else would take the look farther away from the HV10. I've done no experimenting thus far.
The key trick to match them is getting the white balance right. Given the myriad of different temperature lights around the track, it gets a little tricky. Also since I use a wide angle adapter on the HV10, I cannot zoom in to something white to get a good wb. (No break in the action long enough to remove the adapter, reposition the camera, wb, move the camera again and re-affix the adapter.) Regardless, good wb is going to be key.
If you work out something trick, please report back. I'd be very interested in optional looks that might work for both cameras.
Old July 19th, 2008, 07:44 AM   #3
Perhaps this could help...
http://www.hv20.com/showpost.php?p=76101&postcount=38
Lee Small is offline   Reply With Quote
Old July 19th, 2008, 03:44 PM   #4
I did the WB and tryed the Preset 13, not good.
I'll try VividRGB (there is a few of them on the preset list, any idea wich one is best?).
Old July 20th, 2008, 12:58 AM   #5
Here's some other threads you can take a look too
http://dvinfo.net/conf/showthread.php?t=117254
http://www.dvinfo.net/conf/showthread.php?t=116560
LA Color Pros Blog
Old July 20th, 2008, 01:01 AM   #6
Here I have two videos. Both of them were shot with XH-A1 and HV30. I think I can master color matching from both camera. Can you tell which scene is from which camera?
http://lacolor.com/video/hd/?id=LeeK...preciationGala
http://lacolor.com/video/hd/?id=Chri...2008Highlights
LA Color Pros Blog
Old July 20th, 2008, 12:25 PM   #7
Nice demonstration Taky, but i understand most of the color correction is done in post.
You mentionned using VividRGB and Outsiden (#13), wich one give you the best "in camera" similitude of looks?
I'm pretty limited for CC with the FCE 3.5.
Old July 20th, 2008, 12:28 PM   #8
If I will be editing the video I will shoot VIVIDRGB. If I will just pass the tapes to the client, I will shoot in Preset #13 OUTSIDEN in XH-A1 which has the cloest color output to HV30.
LA Color Pros Blog
Old July 21st, 2008, 01:43 AM   #9
My guess is that the first is the HV30 and the second is the A1.
I use a HV30 along with a XHA1 in all my projects and managed to match them quit well by using my own REALITY (version 2) preset in the A1 and specific Custom settings in the HV30 (Color -, Sharpness -, Contrast - and Brightness neutral) + a little CC in post (decreasing the reds of the HV30 a little).
I do multicam edits (in Vegas) with the footage of both cams. Switching from wide shots from the HV30 to Close shots from the A1 back and forth and nobody (except me) sees the difference.
www.cvd-video.nl
Kees van Duijvenbode is offline   Reply With Quote
Old July 21st, 2008, 08:40 AM   #10
No, both videos are shot with both XH-A1 and HV30. All the close shots are in XH-A1. Most wide shots are HV30. All steadicam shots are using HV30 too.
LA Color Pros Blog
Old July 22nd, 2008, 09:31 AM   #11
Tricky!
What do you think of steadicam with HV30 vs steadicam with XH-A1, Taky?
I've read a number of posts that offer the opinion that the HV30 is too light for the Merlin. For my own part, I think the HV30 works very well on the Merlin...and it's a hell of a lot easier to hold than the XH-A1 + Merlin. Have you tried the XH-A1 on the Merlin? Do you find that the XH-A1+Merline is more stable than the HV30+Merlin?
Old July 22nd, 2008, 09:38 AM   #12
I have never tried to mount XH-A1 on merlin. At a shooting job, I will be using 3 camcorders. XH-A1 as main cam, HV30 as b-roll. A second HV30 mounted on merlin. I need it to be small and easy to carry. HV30 on merlin works well for me. I mounted a Raynox 6600 in front and using the BP-2L24H big battery at the end. The merlin set up works very well for me.
LA Color Pros Blog
Taky Cheung is offline   Reply
