clean heads on new XH A1?
I think I read but can't find it now that you should clean the heads on a new camera right out of the box. Is this true?
Contributor
Yes. Definitely. 100% true. Use a head cleaning tape...but don't overuse it. Follow the directions exactly. Usually, that means put the camera in play mode and let the tape run for 10 seconds. NOT record mode.
This goes for any new tape-based camcorder. Never rewind the cleaning tape; just discard it when it eventually reaches the end of the cassette. Ten seconds is the longest you'll want to run it.
Knowledge is golden
Many thanks for the knowledge base.
#5 |
I've never heard of this before. Cleaning the heads on a brand new camera out of the box? What is the reasoning behind doing this?
#6 |
Bill, why should you not use the cleaning tape in record mode?
#7 |
Contributor
Because the camera will try to record on something it can't record on and you could screw up the record heads.
#8 |
If this "clean heads before first use" has any validity or reasoning why do manufacturers choose not to advise this sort of thing. I've never owned a camera that had such a written warning. Is this along the lines of the old "wet vs. dry" blah blah scenario where they also chose not to include some sort of addendum sheet with a new cam purchase?
Silly stuff :) |
#9 |
I must have missed that step in the manual, thought I read the whole thing before turning the camera on. Will any brand work, or is there a super special one to use for the A1?
Hopefully I can just buy it at K-Mart or Sears. I've used my camera for 4 hours of tape, with about 7 hours of playback for editing. Today I noticed during a playback the image in one particular segment freezes for a couple of seconds before continuing. |
#10 |
#11 |
This is off the subject, but have you ever had the tape during playback freeze a frame for a split second before continuing? Same place every time. Is this the proverbial 'drop out'?
#12 | |
Canon XH A1 -Sony DVM-63HD |
#13 |
Anyone care to elaborate on WHY you should run a head-cleaning tape on a new camera? I've never heard of that before, and I've never seen it in a manual. If anything I've learned that you should only use a head cleaning tape very rarely when your camera is showing signs it needs a cleaning.
Why would a brand new camera need it's heads "cleaned"? |
#14 | ||
On his advice, I used several Sony camcorders for 6 and a half years (many hundreds of hours of filming and capturing) on the same brand of tape without cleaning the heads once. This was SD DV not HD, so maybe that's a factor. I'm still very nervous about using abrasive head cleaners. |
#15 |
Colin, thanks for the response. I think I'm with you. I'd rather not start off my camera's career with some abrasive action on the heads.
