Begging for shouldermount design
I'm (a little) mad at Canon. I've spent the better part of last week searching for a suitable bag for my XH-A1 plus Varizoom shoulder rest plus Rode NTG2. The only thing that would fit is one of these mega-suitcases with a width of 70 cm! I refuse to buy that, because these cases are 1 meter high and I would look like the wife has just kicked me out of the house. Seriously, why on earth didn't Canon make this superb peace of equipment in a shouldermount design? OK, there's the XL-H1A or -S, but I'm not Rockefella. Sony has understood that the only good place for a cam, to be in balance, is on your shoulder - or a tripod - and they have made the very affordable HVR-HD1000. Even my old Sony Betamax - the one with the separate 12 kilo recorder - rested comfortably on my shoulder, and that was 25 years ago. Is this called progress? Or am I just being hard to satisfie? I hope the Canon design guys read this and start working on a XH-A1 S. With 'S' for Shoulder. And keep the aperture ring on the lens.
I use the Pelican 1520:
http://www.pelican.com/cases_detail.php?Case=1520 You can drop it in the ocean, shoot it with a shotgun, drop it from the 5th floor, or drive over it with a truck without damaging the camera. Plus it comes in a variety of colors including international orange (great for keeping an eye on it in a crowded place.) And you can take it on a plane as carry on. I got mine from B&H for $130 (It was 115 but was $15 extra for padded dividers instead of foam). |
I have a very comparable case right here, but just as the Pelican, it is only 46 cm wide. The length of the XH-A1 WITH the Varizoom and the mic is almost 70 cm. That's the problem: the camera itself will fit in hundreds of cases or bags, but the complete combination is way too big. And I hate to srew and unscrew the shoulder mount each time. I want to be able to hide the camera (from rain, dust, spray...) in a second if necessary. That does not allow for dismantling the whole setup.
Contributor
Get the Canon quick release tripod adapter plate, TA-100 is the number, I think. Then you can unsnap the camera in a second and stash it. It's about $135 from B&H. This is a good thing to have because in addition to the small 1/4" threads, it has the standard 3/8" threads, so you can use the camera on a full size professional tripod if you ever need to shoot with a teleprompter or something else that requires a bigger tripod. And, it will work great for your purposes too.
As you pointed out, Canon does make shoulder mount versions. the new XL H1a model is down to around $6K or so. Criticizing the XH A1 for not being the XL H1A is sort of like criticizing a 2-door Toyota for not having 4 doors. |
#5 |
Thanks for the tip, I'll check that adaptor plate out.
I'm not criticizing the XH A1 for not being the XL H1A. I just fail to understand why the concept of a shoulder mounted camera was abandoned for the prosumer market. I would pe perfectly happy with a camera that has the specs (and price) of the XH-A1 in an shoulder-mounted package. That this is possible marketingwise, is proven by Sony's HVR-HD1000 and Canon's XL2. Putting a viewfinder at the tail end of a camera is nonsense in my opinion. It belongs in a more advanced position if you want the camera to be in balance. It is virtually impossible to use the XH-A1 - and all other camera's of this concept-with mic and some accesories, just holding it with one hand before your face. Cramps assured within 10 minutes. I had the XL2 and balance-wise it was a much better product. |
#6 |
Checked the Canon tripod plate and that indeed seems a workable solution. Too bad Manfrotto does not sell the tripod-side part of its quick-release mounts separately. Then I could leave the same base plate mounted on the camera for the Varizoom shoulder rest AND the Manfrotto tripod head that I have.
#7 | |||||
Bill Pryor made an excellent point above, about "criticizing the XH A1 for not being the XL H1A is sort of like criticizing a 2-door Toyota for not having 4 doors." I'm having a very hard time understanding what the problem is here in distinguishing between the XH A1 and XL H1A. You need an XH A1 in a shoulder mount design? Presto -- it is done. It's called the XL H1A. I don't see the point in dragging this out any further. |
