best macro lens? at DVinfo.net
Old May 12th, 2008, 07:23 PM   #1
best macro lens?
Hey all,
I'm looking for a kick ass macro lens to use for my xha1. Any recommendations?
-Rick
Rick Oconnor is offline   Reply With Quote
Old May 12th, 2008, 10:03 PM   #2
Are you looking for a macro lens or a diopter?
Jonathan Shaw is offline   Reply With Quote
Old May 12th, 2008, 10:31 PM   #3
Hmm, what's the difference?
Old May 13th, 2008, 12:52 AM   #4
Well to be perfectly honest Rick I don't fully know...
I use diopters on a reasonably regular basis, they screw onto the camera lens like a thick filter and come in different magnification strengths and allow you to get super close / tight shots, eg +1,+2,+3.5 etc
The best type are multi element achromatic e.g. Century however they are around $500. Cheaper ones give more barrel distortion.
You can also stack them to get even closer..
I believe a macro lens are a flat lens that allow you to magnify the image and give a super sharp result...I believe they are pretty expensive
I actually think that A1 you would not be able to get a macro lens because you would need to remove the original lens... i.e. have a XLH1.
I'm sure someone else will clarify but I reckon you need a diopter...
Old May 13th, 2008, 01:59 AM   #5
Gotcha. Yeah, I was taking a look at the xha1 lens and was wondering the same thing (do I have to unscrew it???)
Sounds like the diopters are the way to go. Know of any good resources online?
Thanks again!
Old May 13th, 2008, 02:05 AM   #6
One of the best macro lens designs is an enlarging lens. I have a 50 mm f/2.8 El Nikkor that's designed to work close up and give very flat field reproduction (obviously).
Old May 13th, 2008, 02:56 AM   #7
Would that fit on the A1?
Old May 13th, 2008, 03:00 AM   #8
As with all fixed lens cameras it's a suck it and see situation. With any interchangeable lens camera it's a yes.
Old May 13th, 2008, 09:04 AM   #9
Looks like you would need some step up rings to attach this baby.
http://www.bhphotovideo.com/images/l...ages/36982.jpg
What are you using ring wise to make this work?
Old May 13th, 2008, 03:37 PM   #10
The lens on the XHA1 will focus extemely close when set to wide. Up to a few cm. This can be great, but not always ideal, since the camera might cast a shadow, or you might want to be slightly farther away for some other reason. A diopter or closeup lens is like a magnifying lens, letting you get a closeup from a little farther away.
As you can't change the lens on this camera, the diopter is the only way to go. Canon have 2 - the 250d and 500d. don't ask me about the numbers - I don't recall what they represent - except the 500 is stronger. These will work fine, but really any diopter lens that screws into a 72mm slot should be somewhat OK. Just remember that you get what you pay for.
Bill Engeler is offline   Reply With Quote
Old May 13th, 2008, 06:45 PM   #11
Thanks Bill, I'll give the 500d a shot. Where did you pick yours up at? B&H?
Old May 13th, 2008, 07:17 PM   #12
http://www.vimeo.com/945906
this is a test using a $50 set of dipoters from ebay on the A1
Cheers - Paul M.
www.perbenyik.com
Old May 15th, 2008, 10:33 AM   #13
Best macro lens?
I realize its cost is a bit steeper than some of the alternatives, but I use the Century/Schneider 2.0 Achromatic Diopter and I'm very pleased with it.
In addition to getting in really close when needed, I was also pleasantly surprised with the depth of field it maintains at large magnifications. As anyone who's worked in the macro field knows, depth of field goes to hell in a hurry. The Century glass allows more in-focus movement within the frame than I'd have expected.
An excellent investment if macro work is in the books with an A1/G1.
Jeff Johnston
Jeff Johnston is offline   Reply With Quote
Old May 22nd, 2008, 09:35 AM   #14
Sponsor: Schneider Optics
Originally Posted by Rick Oconnor View Post
Hey all,
-Rick
As many people here suggest, a diopter will increase your working distance and enable shadow-free shots.
There are two types of diopters out there. The first is a regular single element diopter that increases magnification but tends to be soft at the edges.
The second is an achromatic diopter that has two elements cemented together that creates sharp images edge to edge. These are available from Schneider Optics under the Century product. We make them in three sizes; 58mm, 72mm, and 86mm. These can be made smaller with stepping rings to accomodate the filter threads on your camera.
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply
