General purpose stereo mic for the A1
I have tried SMX-10, not so impress. Anybody has any recommendation for a general purpose stereo mic (3.5mm plug or XLR) less than $200?
I like Rode StereoMic. But I want something I can mount in A1's mic holder.
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
I do not have any of the issue you mentioned with my Rode stereo Mic. I guess it depends on how you mount it and how you use it.
I think the AT822 or 825 (same as 822 but w/XLR connect) is a good choice. The 822 sounds very nice, and goes for about $250.
#5 |
Taky, I use the RODE Stereo Videomic with my A1. The advantages are, it fits in the A1 shoe nicely, some don't...and plugs in easily too.
On its own shock mount it sits up there out of the way of any cam body sound reflections and has an easily reachable 10db switch for a quick drop or increase in level if you suddenly need it. Comes with a deadcat, I use it around airfields a lot. And the RSVM has such a sweet sound, I love it. My next preference is my cheaper AT822, also a good sound, but it needs an additional shock mount. Cheers. |
#6 | |
BTW Taky, the HV30 batteries are doing just great - with two I can keep going all day. |
#7 |
Colin, that's great you got the batteries okay. I am using those batteries too! To shoot an evening banquet, I don't have to worry about if the battery running dry :)
#8 |
I use the AT-825 and like it, but usually with a separate recorder, e.g., MicroTrack 24/96
You could also checkout the Sony ECM-MS957 as moderate cost mic in the $200 price range. http://www.sonystyle.com/webapp/wcs/...&storeId=10151
dpalomaki@dspalomaki.com |
#9 | |
http://forums.minidisc.org/index.php...9&#entry120639 I still haven't made my purchase yet, but when I do finally make the jump to the Canon XH-A1 (I currently have a Sony HC1), then I definitely plan to finally get this mic.
Current Audio Equipment: two AT822 mics, Sony MZ-RH1, and KE-110CCR. What else should I get for short films and recording stand-up comedy? http://is.gd/kePy |
#10 |
Taky,
If you are still looking for a way to mount the Rode mic (or any other shock mount) on your A1 please take a look at The J-Rod--It will allow you to mount the mic you want, as well as a radio receiver on the A1. Your top cold shoe will also be left open for the use of a video light or Firestore. www.thej-rod.com |
#11 |
Go Cycle
The RODE SM-5 works perfectly for me.
Lou Bruno |
#12 | |||
I saw that you both had suggested and use the AT-822 & the AT-825. I was wondering which of the two I should get if I would like to use both with my XH-A1 and my Sony MZ-RH1 Hi-MD? Also, what accessories should I get to use with my XH-A1? (also, I plan to use this with a boom pole so I was also wondering what I should get for that, but I think that's outside the scope of this thread).
#13 |
For use with both the A1 and the Hi-MD get the AT822, it's AA battery powered and comes with an XLR to 3.5mm stereo jack cable which will fit both rigs. The AT825 needs 48volts.
There are other options but I got the RODE SM4 shockmount which fits booms and a 3/8" to shoe mount adaptor to fit the A1. Cheers. Last edited by Allan Black; September 16th, 2008 at 03:19 PM. Reason: options |
#14 | |
Thanks for the info on the shockmount too. The SM4 is $49 so that's not bad. I saw some people using the Rycote one over on this Boom pole thread: BOOM poles.... a low level perspective - Page 3 - The Digital Video Information Network. Thats not too bad either at $69 or $79 I believe. I actually JUST bought my XH-A1 used from a member of dvinfo.net (it arrived today actually) and he also has a K-Tek 110CC boom pole he's trying to sell which I'm considering getting (I was eying the Rode Boompole as my other option but the price difference between a new Rode Boompole - $149 - isn't too much lower than his price on the used K-tek boom pole so I think I'm leaning towards getting the better K-tek onr). This seller also has a K-tek GPS shockmount, and as nice it would be to buy both things I need in one shot, those retail new on B&H Photo for $155 which is pretty steep. Even if the seller gave me a good price on his used one, it would probably still be pretty far from the SM4 or Rycote's price. Last question - you said you use a " 3/8" to shoe mount adaptor to fit the A1." Is that sold from b&h photo also? Do you have a specific link? I tried searching around but couldn't quite find it.
#15 |
The 822 has the 3pin XLR to stereo 3.5mm minijack and not the 5pin XLRF type stereo output connector that the 825 has. Audio wise they're very close, I doubt you could tell them apart even in a a pro recording studio. Slightly better figures on the 825. BTW it also has an AA battery option.
Boom poles; each to his own but for prosumer work, my take is get a middle price carbon fibre one, there's nothing worse than underspecing gear, in a lot of instances you buy twice. I couldn't find that B&H page for that shoe adaptor now either, but it's there somewhere, under camera brackets I thought. A good tip is, before you buy any gear, look up the owners manual on the web. Cheers. |
