Fluorescent lighting at DVinfo.net
Old April 15th, 2008, 09:50 PM   #1
Disjecta
Simple light test with some cheapo work lights with daylight-balanced flo tubes (couldn't afford Kino flos so made my own). Flicker free and dirt cheap. I gravitating towards daylight balanced lights now because of the number of times I run across mixed lighting...
I also used a pro light with a snoot for hair light in these shots. No sound.
http://www.pinelakefilms.com/flo/taraflo.wmv
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old April 15th, 2008, 11:36 PM   #2
Did you use your 35mm adapter on this? I ask because the image is extremely sharp.
Eduardo Miguel is offline   Reply With Quote
Old April 15th, 2008, 11:39 PM   #3
Disjecta
No adapter, native XHA1 lens
Old April 16th, 2008, 02:16 AM   #4
Hallo Steven
I like the eye light did you use a special lamp for it ?
Canon XH-a1 user & Edius NX Canopus
Arnold Tersteeg is offline   Reply With Quote
Old April 16th, 2008, 08:09 AM   #5
Disjecta
No, the flos provided the eyelight. This set up is just a key and back light.
Old April 22nd, 2008, 10:52 AM   #6
Fantastic! Did you tweek the camera settings to adjust color and contrast at all?
I have been getting nice results with standard work lights using the GE Reveal bulbs and white packing material cliped to the outside to soften.
Damon Roger is offline   Reply With Quote
Old April 22nd, 2008, 01:26 PM   #7
Disjecta
No adjustment and I didn't white balance which was probably a mistake. There is a greenish hue on her skin that is a result of flo tubes that are not full spectrum... Wonder if this would have been either lessened or eradicated had I white balanced.....
Old April 28th, 2008, 03:00 AM   #8
Wonderful!
Which setting did you use Steven?
Giovanni Speranza is offline   Reply
