Is it possible to capture footage shot on a Canon XH A1 as DVC PRO HD? at DVinfo.net
Old February 29th, 2008, 07:22 AM   #1
Currently working with a lot of DVC Pro HD footage which needs to be cut with some stuff shot in HDV on a Canon. It would make life much easier if all of the footage was encoded the same. I'm using FCP Studio 2 and a Kona AJA breakout box.
Is it possible to go out of the Canon using SDI, into the AJA then into FCP and capture as DVC PRO HD?
Hope someone can help
Stick
Stick Tully is offline   Reply With Quote
Old February 29th, 2008, 07:55 AM   #2
Absolutely. I capture HDV material shot on the JVC cameras this way all the time on a Kona LHe, only I use a deck with RS-422 control. I imagine you could use FireWire for control and SDI for signal, though.
Eric Darling is offline   Reply With Quote
Old February 29th, 2008, 08:20 AM   #3
Originally Posted by Stick Tully View Post
Is it possible to go out of the Canon using SDI...?
The XH A1 is not equipped with SDI, but the XH G1 is.
Old February 29th, 2008, 08:37 AM   #4
Thanks for the reply guys, although that is a shame.
Will have to test out some different settings for the timelines (dvc pro hd, hdv, 422) and see what works fastest for each project
Cheers again
Stick
Old March 2nd, 2008, 11:52 PM   #5
You can capture in ProRes too
if you have the disk space.
It works pretty well, although I have been following
a thread elsewhere that says DVC Pro HD works
equally well with HDV originated material,
you might give that a try.
David
David McGiffert is offline   Reply
