#16 | |
Steam Age Pictures - videos in aid of railway preservation societies. |
#17 |
Hmm, interesting. Never seen before.
Do you want to share a picture of that setup? It sounds to me like the next best thing after a (for me) unpractical basket. |
#18 |
> If I get the NTG-1 will it only operate as a shotgun mic?
Yes, but that is what most folks want for video. The objectiv is to provide some isolation from sounds to the sides and rear of the scene; i.e., from sound sources not in the image. > If I need to not use the shotgun function do I have to unplug it from the camera or can I switch over to the camera mic? The A1 lets you switch between an external and the internal microphone without unplugging it if you are using the XLR input. If the mic uses the 3.5mm mic jack, you have to unplug it. Keep in mind that the "shotgun" capability means that it picks up sound coming at the mic from the front much better than sounds coming at the mic from the sides or the rear. How mecuh batter? Perhaps by a factor of as much as 10, but it is also frequency and angle dependent. Most folks will find that an omni directional microphone is NOT desired on a camcorder. You will pick-up too much operator and handling noise. A good omin is well suited for use by an interviewer as a hand-held microphone in man-in-the-street type interviews where it also serves as a prop.
dpalomaki@dspalomaki.com |
#19 |
Hey guys, i use oktava with my A1 and it is a fab but everybody here talking about the ntg's. i am looking to add another mic with wide pickup. Do you think NTG1 will work. i know NTG2 won't work cuz it is hyper. thx
#20 |
I believe they are basically identical except one is phantom power only & the other gives a battery option as well as phantom. Length differences as well.
#21 |
How wide to you want?
#22 | |
Wind reduction is difficult to measure and difficult to compare one deadcat against another but I had a RYCOTE deadcat on a RODE Videomic for about 2yrs. Last year the rig got rained on so I changed to a RODE deadcat and immediately noticed the lower wind frequencies/rumble was less apparent. It was so noticeable at one point I thought I could probably get rid of the rest with SOAP or similar, didn't try it though. Note: this was a light but gusty breeze. Deadcats do roll the highs off somewhat, try the same speech with and without, but 'with' is preferable in the wind. Using the NTG-2 or similar shotgun, if at all possible work side on to the direction the wind is coming from. Cheers. |
#23 |
Hey Don, i want it to be 180 degree wide. This is for concert and i will be in the back of the hall.
