SHP setting at DVinfo.net
Old December 27th, 2007, 09:18 PM   #1
SHP setting
Sorry for interrupting you again, but I appreciate for your help. I'm trying to make a presets for my needs and can one tell me, how SHP works. Does negative sharpness really MAKE picture blurer, or it just DOESN'T MAKE it sharper? In other words: sharpness is controlled digitally, by DSP or it influences only optics? In which position sharpness function has no influence to the picture at all: when it is -9 or when 0?
Lev Naumov is offline   Reply With Quote
Old December 28th, 2007, 11:41 AM   #2
Hi Lev, good question and one I've not yet found the answer to. It should be easy enough to test with a scope (digital or analogue), by looking for sharpening artefacts... One point, though- while recording with "minimum artificial sharpening" might sound like the best solution (i.e. with the intent of sharpening to-taste in post), but there are other consequences-- how will the image be treated by the mpeg2 codec? If details are too soft then will the mpeg2 codec think it's not an edge, and de-prioritise? Also- if your goal is film-out, the last thing you want is a soft source image. Canon's "Cine" preset has sharpness turned *up*, not down! Just some points which you might already know :) I'll let you know when I've got around to testing, in regards to answering your question directly.
Kris Bird is offline   Reply With Quote
Old December 28th, 2007, 07:04 PM   #3
Thank you beforehand.
Does anyone else can add something?
Old December 30th, 2007, 11:15 AM   #4
Just tested, there's definitely oversharpening/overshoot at SHP=0
Based on limited testing so far, -7 has a tiny bit of artefacting, maybe. -9 has none.
(Note: that *doesn't* mean it really doesn't sharpen at all at -9, just that over-sharpening isn't visible on my scope in front of me right now).
The amount of artefacting at -5 SHP is almost nil, I'm considering this setting for a feature film shoot I have coming up in Feb. I'm worried about losing a little detail though, since obviously when this processing is done the internal DSP has more bits to play with... so too low a SHP setting might be losing info by the time it gets truncated to 8 bits and pumped through the codec. Upshot is that I'll be shooting either -5 or above, artefacts or not.. TBC
Old January 4th, 2008, 05:26 AM   #5
Thanks a lot!
But this looks strange: no artefacts on -9 and -5 and some artefacts on -7. Did I understand you right?
Old January 4th, 2008, 06:17 AM   #6
Sorry if my post wasn't clear-- -9 has none (to my eye), -7 was just about visible.. -5 was still 'practically nil', meaning not enough to worry me! Approaching 0 it became quite obvious/visible.
Old January 4th, 2008, 04:23 PM   #7
Ok, I got it, thanks a lot.
