Built-in mic seems loose? - Page 4 at DVinfo.net
Old June 2nd, 2007, 09:26 PM   #46
It is supposed to be "loose." See also this existing thread:
http://www.dvinfo.net/conf/showthread.php?t=89691
Pete Bauer
Old June 2nd, 2007, 11:24 PM   #47
I was the first to note the observation about the mic.
http://dvinfo.net/conf/showpost.php?...46&postcount=4
I am so PROUD! (it's still loose though...)
Old June 9th, 2007, 09:57 AM   #48
XH A1 stereo mic is getting loose
My on-board mic is about to pull out. Anyone know how to tighten this thing?
David Morgan is offline   Reply With Quote
Old June 9th, 2007, 10:03 AM   #49
Mic
I glued mine back on.
Ryan
Ryan Flesher is offline   Reply With Quote
Old June 9th, 2007, 10:06 AM   #50
Permanent glue like crazy glue? I wonder what Canon recommends? If you ever needed to service this thing, I suspect you'd never get it apart?
Old June 9th, 2007, 11:49 AM   #51
Lordy! If it just wiggles a little, this is normal. Hope you didn't fall into the glue scenario.
If it's near dangling, then a trip to service is in order
Bill
Old June 9th, 2007, 02:37 PM   #52
Well, it does sound like I'm not the only one who is having this problem. There are, what appears to be screw holes on the bottom side but access would require a special tool or something because the lens is in the way. It's way looser than when I bought the camera. Not quite falling off yet. I'm surprized that there aren't other threads addressing this issue.
Not only that but, it's starting to ring of what my intial concerns are about these cameras. They aren't built to take much physical abuse. Too much delicate plastic. Just look at the battery compartment and the release lever.
regards
dm
Old June 9th, 2007, 03:07 PM   #53
So don't physically abuse your $4000 camera? ;)
Good-natured kidding aside, there are lots of other threads about this; the mic is shockmounted to reduce camera and handling noise. If the mic is in fact getting looser with time as you suggest, then you might have a legitimate problem. However, I'd suggest not worrying about it too much unless the mic actually does fall off or something. Maybe it's just "settling in" to its natural state, who knows? I suspect that you might feel the need to fix this before it fails in a critical situation, but then if you're using a built-in mic for something critical, then you've probably got bigger problems to begin with.
Take all of the above for what it's worth. I may or may not have any idea what I'm talking about. :)
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old June 9th, 2007, 07:59 PM   #54
yep, well, I really do take care of the camera. However, I have a lot of stuff jammed into my camera case. Headphones, shotgun mic, shock mount.....the list goes on. I suspect that the mic took some unintentional upward or downward pressure. It moves at least 1/4" up and down. Definitely getting loose.
On the subject of usage, I try not to use it for a lot of reasons. However, I just recorded something outdoors and there was just enough wind to create a problem with my outboard shotgun mic with windscreen. I don't have a zepplin or deadcat etc... as I don't shoot outside very often. Had to resort to the onboard mic. Definitely not my first choice but saved my bacon.
regards
dm
Old June 17th, 2007, 01:30 AM   #55
I just got my XH A1 yesterday, and before I even shot with it, I noticed that the built-in mic was loose. It's now even making a noise like there is something loose inside it, I hear in the audio and when just lightly shaking the camera. I just wanted to make sure that this is what you guys are talking about. Is mine worse? Thanks.
Luke Burns is offline   Reply With Quote
Old June 17th, 2007, 04:20 AM   #56
Mines loose also, it's just the way they are built. I think using a small screw driver (for glasses) you'll be able to tighten the screw on it. I haven't tried yet. I don't tend to use the on board mic, unless it's purely as a guide track.
Kathy Stannard is offline   Reply With Quote
Old June 17th, 2007, 12:08 PM   #57
It is SUPPOSED to be loose. We've discussed this here many times. If it's NOT loose, there's something wrong. See http://www.dvinfo.net/conf/showpost....40&postcount=7 for details. Do NOT try to tighten it. It's made that way for a reason.
Old June 18th, 2007, 07:44 AM   #58
Hmmm. Sounds like someone needs to create a bit of persistent video or graphic image showing the "normal" range of motion of the built-in mic. Too many folks obsessing about it, and a fair number no doubt needlessly.
dpalomaki@dspalomaki.com
Old July 25th, 2007, 06:12 AM   #59
Wobbly A1 Mic
Hi,
the built in Mic on my A1 is very wobbly, I expected it to move a little for shock absorbtion.. but mine seems to rattle away from the rubber or soft element inside. Anyone had the same problem? Is there any way to adjust it?
Steve
Steven Taylor is offline   Reply With Quote
Old July 25th, 2007, 07:07 AM   #60
Normal. Frequently asked. Merging w/several earlier threads.
Chris Hurd is offline   Reply
