Capture problems with an HV20 and FCP 602 at DVinfo.net
Old December 6th, 2007, 10:05 PM   #1
Images: 2
I cant get the damn thing to recognize the HV at all. Camera off => start log and Cap => cam on, No dice. Camera on => start log and cap, no dice. Cant find the damn camera. I have been capturing to iMovie, but i hate using that program since it takes so long to process the friggen thumbnails.
Ideas? I have 17 hrs of footage to capture...
Derek Nickell is offline   Reply With Quote
Old January 28th, 2008, 01:16 PM   #2
I am in the same boat, I am not sure exactly of when it happened, three weeks ago I installed a new installation of Leopard, not an upgrade.
C.J. Daniel is offline   Reply With Quote
Old January 28th, 2008, 01:32 PM   #3
Images: 2
Try the easy setup, worked for me.
Go to easy setup => HDV => HDV 1080 and whatever frame rate you are using.
Old January 28th, 2008, 02:28 PM   #4
easy setup does not work
removing pkg files from qt library does not work
uninstalling qt 7.4 and installin 7.3 does not work
Old January 28th, 2008, 02:31 PM   #5
Images: 2
Wow, ok...I don't know if this would be a problem with Leopard or not. I haven't installed it yet. But I know that i played with the easy setup prefs and it worked, at least for me anyway.
