UV filter (for protection) for the XH-A1 - Page 2 at DVinfo.net
Old November 26th, 2007, 06:10 PM   #16
Originally Posted by Ger Griffin View Post
the hoya UV filter I use seems to cause lensflare
to show up a bit sooner than without it.
maybe that could be the difference between the 2 pieces.
Which hoya uv filter are you using?
Stephen Sobel is offline   Reply With Quote
Old November 27th, 2007, 10:00 AM   #17
i couldn't tell you exactly but its definately a cheap one. its threaded on the outside also if i need to add another filter.
Ger Griffin is offline   Reply With Quote
Old November 27th, 2007, 11:31 AM   #18
Sponsor: Schneider Optics
Originally Posted by Stephen Sobel View Post
I've finally joined the ranks of XH-A1 owners!!! Now I'm looking for a UV filter to put on all the time for protection. I'm considering a Hoya filter. B & H has several.
There is the Hoya 72mm Ultraviolet (UV) Pro 1 Digital Multi-Coated Glass Filter for $73.50. The website is:
http://www.bhphotovideo.com/c/produc...et_UV_Pro.html
There is also the Hoya 72mm Ultraviolet UV(0) Haze Multi-Coated Glass Filter for $37.50. The website is:
http://www.bhphotovideo.com/c/produc...UV_0_Haze.html
Is the first one really worth virtually twice the price? Is there a noticable difference in how they affect the video quality?
The Hoya is a quality product for sure. I would recommend (obviously) that you give our B+W MRC filters a look. The major differences are that ours are made from Water White German Schott glass which is the finest glass available. They are also feature our exclusive Multi Resistent Coating which is a hard coating that repels water and dust better than any other filter on the market. Also, our filters are made from a brass ring.
http://www.schneideroptics.com/ecomm...D=671&IID=4481
Abel Cine Tech is an official dealer for Schneider Optics imported B+W filters. If you buy from them or other official US dealers you will get a 10 year warranty on the filter.
Also, the price on the filter should be about the same or less than the Hoya.
Ryan Avery
Regional Sales Representative
Schneider Optics
Ryan Avery is offline   Reply
