On camera mic mount at DVinfo.net
Old November 5th, 2007, 09:40 AM   #1
Images: 2
On camera mic mount
So, i dont know if this has been covered or not, but I went to put my AT4073 on my A1 and it doesn't fit? So I did the whole paper towel trick on the mic and made it work for the time being. Anyone know of a different mic mount that replaces the original one so that it will fit the mic tight like it should?
Thanks in advance.
Derek
Derek Nickell is offline   Reply With Quote
Old November 5th, 2007, 02:18 PM   #2
Generally I think users get a shoe mounted shockmount and use that. I find the on-camera holder works easily enough if I slip a small piece of foam in there.
www.philipwilliams.com
Philip Williams is offline   Reply With Quote
Old November 5th, 2007, 04:22 PM   #3
Images: 18
Hi Derek.............
The Rycote CCA adapter works a treat, snug fit into the mic mount, lifts the mic an inch and half higher from the camera, has excellent isolation and can be fitted backwards, allowing long shotguns to be more towards the rear of the camera and thus out of frame when using dead cats.
Worth checking out. There are other similar products around as well.
CS
Old November 5th, 2007, 04:33 PM   #4
Images: 2
So, canon doenst make a replacement for the on camera mount...what a bummer..
Old November 5th, 2007, 07:08 PM   #5
I second Chris's suggestion. I've been using the CCA since I bought my XH-A1. The only time I've had issues with it is when the wind is pretty strong. It sits up high enough to catch the wind and shake the camera.
Michael
Michael Foo is offline   Reply With Quote
Old November 5th, 2007, 09:48 PM   #6
I use a Rode SM5 shock mount, fits in the existing A1 clamp raising a shotgun mic in a banded vibration mount above the wide angle adaptor FOV and dead cat stray fur.
Malcolm OBrien is offline   Reply With Quote
Old November 5th, 2007, 11:10 PM   #7
Images: 2
Yeah i think i have a old Azden hot-shoe mount that might work...thx for the input guys.
Derek
Old November 9th, 2007, 06:22 PM   #8
spacer
Hey, when I was shopping for cameras, one store had this rubber insert ring in the XH-A1 for holding regular sized mics. It turned out to be a sony part. I was able to order it from Sony Parts directly.
http://servicesales.sel.sony.com/eco.../web/index.jsp
Here's the part number (thanks to another DVInfo member)
317988201
SPACER, MICROPHONE
Jeremiah Rickert is offline   Reply With Quote
Old November 13th, 2007, 10:14 AM   #9
I use a Beyer Dynamic EA86 shock mount on a Hama angled hot-shoe extension. This neat little Hama gadget raises the mic about 2 inches and allows it then to be angled up a bit more, to keep the dead cat out of view. The two items together were less than £20 and work very well.
Steam Age Pictures - videos in aid of railway preservation societies.
Mark Fry is offline   Reply
