When and if to White Balance... at DVinfo.net
Old November 4th, 2007, 07:41 PM   #1
If Im using a Moose Filter (Poloraizer/warming) should I manually White Balance?
If so do I balance with the filter on, or off?
I was playing around with it the other day and with the AWB on everything had a Greenish tint. I figured its because of the White Balance.
Also, if Im shooting some Sunrise footage, how often do I have to White Balance if the Color temp is constantly changing.
Mike A.
Michael Azzarello is offline   Reply With Quote
Old November 4th, 2007, 09:24 PM   #2
Mike,
You should always white balance before each shoot. Also take off any filters (other than UV) that you have before white balancing.
White balance:
For sunrise/sunset I usually use the AWB since, I think the AWB does a good job during these times in keeping the mood warm. White balancing at these times takes away the warm look. I deffinitely don't get a greenish tint during these times.
So you could white balance with a warming card or like you have, use a warming filter after white balancing.
Note that white balancing is basically to tell the camera what is white for the given light. In the case of sunrise/sunset you actually (most people I know) don't what white to look white.
Canon XH-A1, Libec LS-55M, Letus Extreme, Steadicam Merlin, PPro CS3
Shiv Kumar is offline   Reply
