Public Info film shot on A1 at DVinfo.net
Old September 25th, 2007, 03:34 AM   #1
Hello
Shot a UK public info film on the A1 (25fps, 720p, 34mb download):
http://www.eyecatcherfilms.com/Drive...h.264_(mq).mov
It's heavily compressed h.264, blocky compression artifacts are all quicktime's, not visible on the original.
Tim Follin is offline   Reply With Quote
Old September 25th, 2007, 11:23 AM   #2
Well done.
Did you use a 35mm adaptor or did you do the blurred edges in post?
Michael Friedman is offline   Reply With Quote
Old September 25th, 2007, 11:34 AM   #3
Images: 2
How did you get the slow motion to look so good, not all blocky? You shot in 60i for that and slow it down?
Derek Nickell is offline   Reply With Quote
Old September 25th, 2007, 03:32 PM   #4
Thanks Michael, the blur was done in post, and was really an attempt to signify the flashbacks rather than simulate depth of field.
Derek, for the slow motion I shot at 50i (PAL) with the shutter at I think 1/150th, to reduce motion blur - I find shooting with higher shutter speeds helps the slow motion. In post I used ReelSmart fields deinterlacer set to 2x, but I set it to blend the fields rather than interpolate, as it's a lot quicker to render and I think actually looks better.
Old September 25th, 2007, 03:34 PM   #5
Images: 2
Sounds great, going to have to try that when I get my A1.
