Aspect ratio question at DVinfo.net
Old September 13th, 2007, 06:49 PM   #1
Another newbie question.
What is the relationship betweem 1.333 and 16:9? What I mean is although I know 16:9 is an SD format, is 1.333 similar? When I am seeing a DVD in letterbox format, has that been converted to 16:9, or is it some other ratio?
Jeff Yin is offline   Reply With Quote
Old September 13th, 2007, 07:57 PM   #2
There is no relationship. 16:9 is an aspect ratio, a common one. 1.333 is a *pixel* aspect ratio used by some formats (e.g. HDV 1080).
An aspect ratio describes the shape of the entire frame. A *pixel* aspect ratio describes the shape of individual pixels.
A widescreen DVD contains an image with 720x480 pixels (3:2 ratio) but they are stretched by a factor of 1.2 (the pixel aspect ratio) during playback to make the frame appear in 16:9 aspect ratio (864x480).
Daniel Browning is offline   Reply With Quote
Old September 14th, 2007, 12:29 AM   #3
In addition to Daniel's correct comments, 4:3 DV is also 720x480 (NTSC), but with a pixel aspect ratio (PAR) of 0.9. Then 1.2 / 0.9 = 1.33. So the 1.33 is the difference in PAR between 4:3 and 16:9 and also the difference in image aspect ratio since they contain the same number of pixels. If you make the shape of the pixels of either one of them square instead of "stretched" or "squashed," the pictures will have, just as Daniel said, a picture W:H ratio of 3:2.
Just for clarification, the 864x480 is what a 16:9 image would be if you resampled it to square pixels, rather than 1.2 PAR, which some software programs and add-in cards do.
Pete Bauer
Pete Bauer is offline   Reply
