BNC Output to Monitor at DVinfo.net
Old September 10th, 2007, 07:38 PM   #1
I own a new JVC TM-H150C and im loving it. I want to hook my A1 up to the thing for on set viewing. I need a BNC Cable right? I looked it up and saw all sorts of kinds, different connectors and stuff...50 and 75 connectors or w/e they're called. I don't want to spend money if im not positive im buying the right cable.
The monitor I have is exactly like this:
http://www.bhphotovideo.com/c/produc...roduction.html
- Kyle
Online Portfolio | Feature Film on XHA1
Kyle Prohaska is offline   Reply With Quote
Old September 10th, 2007, 08:47 PM   #2
Contributor
You just need an ordinary BNC cable. You can get one at Radio Shack.
Old September 10th, 2007, 09:46 PM   #3
Specifically get a 75 ohm BNC cable - video uses 75 ohm cable while a lot of other applications use 50 ohm. This WILL make a difference in anything but a lo-res surveillance cam... Steve
Steve Leverich is offline   Reply With Quote
Old September 11th, 2007, 06:38 AM   #4
Using the wrong impedance cable can result in some ghosts caused by signal reflections induced at a change in impedance. On short cables it may not be noticeable, but it may be visible on longer cable runs. As stated above, video normally uses 75 ohm impedance cables.
dpalomaki@dspalomaki.com
Old September 19th, 2007, 11:10 PM   #5
I'm so confused....and aggrevated. Normal BNC wont work because they are Male to Male when I know the A1's output and the one on my monitor dont match. I know the input on the monitor is a BNC female because I looked up pictures of adapters and things but the A1's output looks different so does that mean the A1's hookup is Male? I'm not sure though because all male cables I see dont look like the A1's output....what a nightmare.
- Kyle
Old September 20th, 2007, 12:53 AM   #6
I'm confused as well, but only from your confusion.
Here's some photos to clear things up for you.
Old September 20th, 2007, 06:27 AM   #7
See that I understand, but for some reason the connector on the A1 looked nothing like either, its empty inside with a single long metal pin in the center, BUT the pin doesn't have a point on it like the Male BNC...hense my confusion. Thats why because the one on the A1 looked like niether...
- Kyle
Old September 20th, 2007, 06:32 AM   #8
The A1 has a female spot.
That sounded raunchier than I meant.
Matthew Nayman is offline   Reply With Quote
Old September 20th, 2007, 07:36 AM   #9
Geesh! Thanks Matthew. I spewed coffee everywhere :-\ Dang
Old September 20th, 2007, 07:54 AM   #10
Originally Posted by Kyle Prohaska View Post
the connector on the A1 looked nothing like either, its empty inside with a single long metal pin in the center, Kyle
I see what you're saying... I think... it's the white plastic shield you're saying is missing. Look further, it's there, just not exactly like the photo posted.
Stop worryin' & get yourself a good BNC cable (male on both ends) & hookerup! :D
Bill
Old September 20th, 2007, 05:51 PM   #11
No problem Bill....
You gotta admit, the camera is certainly a 'her'.
My XL2 was male, reffered to it as 'him' or 'the big boy'. It was stubborn, powerful, top heavy and ugly.
The XHA1 is certainly, in my books, female. It's softer and subtler, an elegant machine. Also, mine freaks out with dropouts and condensation about once a month, so... yeah.
All kidding (and sexism/misogyny) aside, the BNC on the camera is female. The white plastic piece is simply hidden.
Old October 17th, 2007, 07:32 AM   #12
TM-H150C as an HDV Monitor?
I have a Canon A1 but I didn't think this JVC monitor would display as a production monitor when working with HDV. Is anyone using this combination?
Greg Clark is offline   Reply
