#91 |
No. Its a car PC thing with 640x480 resolution, but its a piece of...
#92 |
Some really nice setups here.
You can see my setup on: Picasa Web Albums - Gerdy - Gear http://www.dvinfo.net/forum/members/...canon-xha1.jpg Greetings G Last edited by Gerdy Vandermeersch; September 30th, 2009 at 06:28 AM. |
#93 | |
wow....diy? where to buy ? |
#94 |
The latest:
Really loving the SGblade. |
#95 |
Is it me or does that adapter look about a foot long! Do you loose much light through it?
#96 |
I think it's just the perspective-it's the amazing SGblade. Loses less than half a stop.
#97 |
Its one of the prototypes made aby an polish company. Cost ~300USD.
If you wanna buy similar - contact me under ivamos@wp.pl and i give you contact to the company. |
#98 |
Re: xh a1 setup pictures
Resurrecting an ancient thread, I thought I'd show you my setup of the XH A1S that I use to shoot professional football in the Scottish Professional Football League (SPFL) for Dumbarton FC.
I don't get paid (although have benefitted from a little bit of sponsorship) so everything is as low budget as possible. The camera is the XH A1S, recently serviced, and I shoot both tape and to Compact Flash cards using a Datavideo DN60. I bodged together a mount for the DN60 on the rear of the handle, which swings the DN60 out of the way if I need the viewfinder. Because the camera's onboard monitor is small, and shooting through the viewfinder is difficult when following the sometimes fast action, usually shooting from relatively cramped areas, I use a car reversing monitor (which I "weatherized") mounted either on top of the camera's handle, or else on a mount on the side of the tripod (which is Libec T68 legs, and the Manfrotto 502A head). The monitor image obviously isn't HD, but it is in general good enough to help me keep the ball in the frame. Both the monitor and the DN60 are powered using a battery bank which outputs 5V. I use a small shunt between the battery and the monitor to push the voltage up to 12V. The Dn60 works fine with 5V, which means I don't have to worry about power, since the battery life of the XH A1S is incredible, easily a full 90 mins, plus post match interviews etc. and still half full at the end of the day. The rain cape is a plastic bag that a pillow came in which I altered a bit to fit the camera! I also have a fitted cover mostly to protect the controls. |
#99 |
Good to see an older tool still in use!
dpalomaki@dspalomaki.com |
#100 |
Canon XH A1 and Datavideo dn60a placed in microphone's position
