xh a1 setup pictures - Page 4 at DVinfo.net
Old May 8th, 2008, 11:51 AM   #46
Originally Posted by Josh Chesarek View Post
So you are using the GC2000, with a quick release? I assume its working well for you? I might want to do that as I have to rebalance each time but I have gotten pretty good at it.
Yes, I only used it once on and off before I decided that i needed the quick release. Its sooo much faster and only takes a second to balance it once you have to put it back on. Definitely worth it!!
Matt Bishop is offline   Reply With Quote
Old May 8th, 2008, 12:42 PM   #47
Originally Posted by Matt Bishop View Post
Here is my new setup. I have two identical setups like this one and am also using an hv20
Canon Xh-a1
Hoodman h300 lcd hood with magnifier
audio technica shotgun mic
right angle coiled XLR
sony large eye cup
glidecam 2000 ( it's heavier but is balanced perfectly and works great!)
What model # is your mic?
David Del Real is offline   Reply With Quote
Old May 8th, 2008, 02:50 PM   #48
Originally Posted by Matt OBrien View Post
Nothing radical here, I'm in love with the blue star eye cup though. One of the best $8 I've ever spent, and on a superficial level, it perfectly accents the red ring on the lens.
Hey Matt, do you remember what size that eye cup is?
Is it the "Oval Long" - http://www.bhphotovideo.com/c/produc...icrofiber.html
Or the "oval large"
http://www.bhphotovideo.com/c/produc...eece_Oval.html
Very good thread, all the pictures are very helpful!
Paul Podraza is offline   Reply With Quote
Old May 8th, 2008, 06:18 PM   #49
Another set-up
Here's my A1's typical set up:
IndieSnap Mattebox
IndiFocus Follow Focus and Rails
old Bogen 3068 Tripod
Marcel D. Van Someren is offline   Reply With Quote
Old May 8th, 2008, 08:08 PM   #50
IndieSnap Mattebox
How do you like the IndiFocus? How well does it work? Are there any problems? Do you have the old or the new gear box? Thanks!
Old May 8th, 2008, 08:18 PM   #51
It is the AT875. The short shotgun. So far I really like it !
Old May 9th, 2008, 07:04 AM   #52
I believe it's the new geat box since I only got it a month or so ago.
Personally, I feel it's a great piece of hardware. No problems, what so ever, except that it has spoiled me. Once you get used to pulling focus with a Follow Focus, it's hard to go back to a bare camera.
Old May 26th, 2008, 11:55 AM   #53
Hi Marcel,
I like your set up. Would you share how long does it take to get you ready for a shoot, etc? These Indi people do also an upgrade for handle grip and shoulder pad, would that go well, what do you think?
Just asking as am looking for a decent matte box solution yet indie
Regards,
Pavel
The fish is the last to know the water.
Pavel Tomanec is offline   Reply With Quote
Old May 26th, 2008, 12:05 PM   #54
This is mine with RODE NTG1 :)
LA Color Pros Blog
Old May 26th, 2008, 01:19 PM   #55
Originally Posted by Pavel Tomanec View Post
Hi Marcel,
Regards,
Pavel
I usually keep it assembled in a large hard case. But to assemble it takes under 10 min.
I saw their shoulder mount set up. It would probably work pretty well. I think I would figure out some kind of counter balance system and add it to the shoulder pad to help balance the camera since it is fairly front heavy with that gear attached.
Old May 26th, 2008, 11:57 PM   #56
Here is mine, on M2 roids.
http://i100.photobucket.com/albums/m...9/DSC02298.jpg
<a href="http://s100.photobucket.com/albums/m11/swineninety9/?action=view&current=DSC02298.jpg" target="_blank"><img src="http://i100.photobucket.com/albums/m11/swineninety9/DSC02298.jpg" border="0" alt="Photobucket"></a>
Jimmy Moss is offline   Reply With Quote
Old June 5th, 2008, 11:24 AM   #57
[QUOTE=Marcel D. Van Someren;883457]I usually keep it assembled in a large hard case. But to assemble it takes under 10 min.
Thank you for the info. Would you please post a picture of the case and where it is available? I wonder whether it fits on the air plane in-cabin storage space.
Regards,
Pavel
Old June 5th, 2008, 01:11 PM   #58
Or the "oval large"
Hey, sorry about the delay. I bought the "Blue StarOval Small Eye Cushion." Here is the link:
It fits just fine, although the soft foam type backing material gets a little stretched out if you're taking it on and off frequently. It does return to its original shape after a few hours of being left alone. It really makes the view finder more comfortable and easy to use for long periods of time. It breathes well, probably not as well as the chamois version, but plenty fine for me. I suppose you could mount it more permanently or go the Sony eye cup route.
Cheers
Matt OBrien is offline   Reply With Quote
Old June 5th, 2008, 01:45 PM   #59
Originally Posted by Jonathan Shaw View Post
Just to add a little diversity... here's my A1 in Gates housing
That's not a camera! That's a TRANSFORMER!
http://www.hdvinfo.nl The Dutch forum and website about HDV & Canon XH-A1
Gert Kracht is offline   Reply With Quote
Old June 5th, 2008, 05:49 PM   #60
Regards,
Pavel
The only place this case will fit is in the belly of the airplane in the cargo bay. Its a Hardigg case. It's military surplus. I got it on ebay for about $40. I just added the custom cut-out foam.
Here are some pics (The last pic was from the ebay auction):
