I Lost My Xh A1 Lens Cap at DVinfo.net
Old September 4th, 2007, 02:15 AM   #1
does anyone know which canon lens cap is the appropriate replacement for the xh a1 if you lost the one it came with? and where to find one cheap? haven't tried that hard to find one but this place usually gets results.
does anyone have one in the uk as that would be even better?
cheers, Giles
Giles Ripley is offline   Reply With Quote
Old September 4th, 2007, 02:45 AM   #2
Call Canon Service Center (or similar).
I'd guess about 20 GBP or so.
Mats Frendahl is offline   Reply With Quote
Old September 4th, 2007, 04:36 AM   #3
i think just any no name 72mm snapcap should work...
find in any better foto-store...
regards - dom
cheers, Giles
Dominik Gehring is offline   Reply With Quote
Old September 4th, 2007, 06:26 AM   #4
Since I too tend to lose lens caps, I purchased a couple of these:
http://www.bhphotovideo.com/c/produc..._Lens_Cap.html
I actually like it better than the one Canon supplied with the A1.
Glen Johnstone
Glen Johnstone is offline   Reply With Quote
Old September 4th, 2007, 09:57 AM   #5
I put a cap keeper on my lens cap. The drawback to that was that now the cap hung loose and got tangled and banged into things (noise). I fixed that by putting a little chunk of velcro on the cap and on the outside of the A1's hand grip. Now I can take the cap off and "stick it somewhere". If the velcro fails, the cap still hangs by the elastic cord.
-- Larry Chapman
Larry Chapman is offline   Reply With Quote
Old September 13th, 2007, 01:01 PM   #6
thanks guys, sterling advice. should be sorted in no time - no more cling-film!
Old July 7th, 2010, 09:08 AM   #7
Canon - 72mm Snap-On Lens Cap - 2728A002 - B&H Photo Video
This is not available any more ...any other suggestions? Also 72mm is the correct size with the XHA1 lens hood attached, right?
Thanks very much,
Randy
BTW, I don't see anything in the manual regarding the "external control mode" selection but is it safe to assume that is just for a lanc controller?
G. Randy Brown is offline   Reply With Quote
Old July 7th, 2010, 11:58 AM   #8
Images: 18
Hi, GRB.................
A bit "off piste" for this thread, but I assume you're talking about "Digital Video Control" (page 70 of the original PAL XH A1 manual).
The Lanc has no user settings whatsoever.
DVC requires that [DV CONTROL] in [SYSTEM SETUP] is set to [ON] on the master system. The "slave" must be set to [DV CONTROL] = [OFF]
Once enabled, it allows the camera to control the function of another compatible HDV/ DV device that is connected via Firewire.
Amongst other things, it gives the ability to have a tape recording at all times, even if one camera needs a tape change.
Cool, if about as useful as an ash tray on a motorcycle (IMHO).
CS
Old July 7th, 2010, 12:50 PM   #9
Assuming "off piste" means off topic... sorry but I thought it would be a quick BTW question with a simple yes answer but now I'm confused.
Okay, Digital Video Control is covered on pg 74 of the NTSC manual and is not what I'm talking about (however I found this feature quite handy when I used to do 2 cam shoots with my old XL1S' ).
Lanc controller would be used for a wired remote to zoom/focus....you probably already know that but I guess to get to the point, my question would be,what is the "ext cont" selection for on the power wheel (next to VCR/play).
Randy
Old July 7th, 2010, 03:11 PM   #10
cheers, Giles
Most large camera shops have an odds box with lens caps etc. Phone around at off peak times.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old July 7th, 2010, 03:20 PM   #11
Thanks Allan, I googled around and B & H has some that'll work.
Thanks again,
Randy
Old July 7th, 2010, 04:06 PM   #12
Images: 18
Ext Cont..............
On the Power dial is shown on page 11 of the later Canon XH G1s / XH A1s manual.
It's annotated "Reserved mode for future software developement", which I guess is another way of saying it does squat (at this point in time and firmware level).
CS
Old July 8th, 2010, 02:04 PM   #13
any 72mm generic lens cap should work fine; i use a nikon lens cap and a nikon knockoff interchangeably; i prefer the inner pinch ring. i think i paid $3 for it.
Panagiotis Raris is offline   Reply With Quote
Old July 8th, 2010, 02:46 PM   #14
Be nice if Canon had included a built in flip up lens cover like they do with their HV20-30-40 series. Cheers.
Old July 30th, 2010, 02:49 PM   #15
One of the first things I did when I got my XL2 several years ago was to put a piece of velcro on the outside face of my lens cap, with the corresponding piece on the top of my lens hood. So when I remove the cap, I can just stick it to the top of the hood where it is ready when I need it. It doesn't get lost that way, and doesn't bang around making noise if hanging by a string, as is common with consumer models.
Just my 2 cents.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply
