#16 |
Contributor
Nope. That's what it's for, to leave on all the time. The only time a UV makes any noticeable difference is if you're shooting a mountain in the distance or doing aerial photography, and it allegedly will help eliminate some of the haze look.
#17 |
you can leave the filter on all the time unless you are very particular about quality or there is a light source in the frame.
#18 |
#19 |
no - if there is a light source in the frame any filter can cause ghosting.
#20 |
Sounds like if I want a filter on for full-time protection, a UV Haze filter is the best - covers outdoors and indoors situation.
From the comments, both the Hoya and B+W are excellent options. Thanks to all of you for the advice and comments. |
#21 |
Whatever filter you take, there's one risk I experienced: the camera becomes much more sensitive to lens flare effects in clear sunlight. Problem is you don't notice it necessarily on the displays, but afterwards during editing.
Probably a bigger lenshood will help you, but it doesn't make your gear leaner in practical use. |
#22 | |
#23 | |
I use the www.cinetactics.com dv soft matte box they suggest for the xha1 and it works great for lens flares. I have a uv filter threaded on and then the adapter ring threaded on my filter that allows the matte box to be added. Its a great product and cheap compared to other matteboxes. Plus its soft!! |
