Multiple preset zoom and focus at DVinfo.net
Old August 10th, 2007, 05:28 AM   #1
Via Lanc there exist a range of remote controls to control zoom and focus, like the VariZoom series.
Have anyone seen similar controls where, e.g., one could preset 16 focuses and 16 zoom levels? It must be a "simpel" task for any E-engineer with knowledge in the Lanc Protocol to make such a unit.
Would be great to have.
Mats Frendahl is offline   Reply With Quote
Old August 14th, 2007, 03:27 AM   #2
Hi Mats. Do you know which varizoom model can control focus on an XH-A1?
Richard
Richard Hunter is offline   Reply With Quote
Old August 14th, 2007, 05:27 AM   #3
Hi Richard,
I'm thinking of buying the
http://www.varizoom.com/products/controls/vzpgl.html
or
http://www.varizoom.com/products/controls/vzprol.html
They both seem good. I don't know what differs them in technology, other than one is "pistol grip". Some 30 USD more also.
What I can see from their page all their models have a Focus control.
I think I'm leaning towards the "VZ Pro-L", the focus buttons are under the casing on that one, above on the other. Could be better to have away from the zoom lever so no "focus accidents" can happen...
That one along a 100ft cable will have it remotely controlled (not pan and tilt). Neat.
Their "VZ CS1LK Dual System" is cool, but the price...
Old August 14th, 2007, 07:59 AM   #4
Thanks Mats for the info. I'm not really keen on adjusting focus with buttons. I always seem to overshoot and then have to hunt back and forth. What I'd like to see is a controller with a rotary focus knob but so far I haven't come across one for the A1.
Richard
Old August 14th, 2007, 08:30 AM   #5
Richard, aha, you mean a remote focus wheel? Nope, haven't seen any, it would be great though. I've seen such on old film cameras where a designated "focus man" took care of the focus while the "camera man" took care of the framing. It was a big mechanical thing where they wrote markers and stuff on the dials to quickly go to correct focus. This was 20 years ago. Today they are prob. digital and with very high price. Strange there is no 3rd party comp. doing more Lanc controllers.
Old August 15th, 2007, 04:30 AM   #6
Yes, something like that. The A1 focus ring action is very strange, because the angle of travel required to shift focus varies greatly with the zoom setting. At the tele end the focus control is quite fine, but at the wider end you go from zero to infinity just by thinking about touching the ring. It would be great to have a LANC controller focus wheel that had a scale showing metres and worked repeatably. I expect there's a technical reason with the A1 lens design why you can't seem to get one of these, cos I doubt if the electronics required would cost that much.
Richard
Old August 15th, 2007, 05:23 AM   #7
Don't think there is anything strange about that as depth of field depends on focal length. Wide-angle coupled with a small image sensor means minimal shift from close to infinity - you get as much control as you need.
Rene Roslev is offline   Reply With Quote
Old August 15th, 2007, 07:10 AM   #8
Hi Rene. I'm not talking about depth of field, just the focus distance setting. It's possible I don't understand the relationship between focal length and the angle of rotation required to change the focus distance - actually it's not just possible, it's a fact - but I don't see why the lens focus behaviour needs to be this way, seems to be just how the servo designer decided to do it.
As for getting as much control as I need, I wish it were so! I would really love to have a calibrated dial with distance markings that was repeatable and dependable at any zoom setting.
Richard
Old August 15th, 2007, 08:41 AM   #9
I also think the focus wheel is far too sensitive ( I've told Canon this ). It is better at zoom, naturally - but ten or 20 times more movement would be far more useful at both ends.
Glenn French is offline   Reply With Quote
Old August 15th, 2007, 04:20 PM   #10
Yes, the ratio with which the ring works is kind of odd, but perhaps one learns... in time for "XH A2" where Canon changes it again... ;)
Perhaps the Lanc protocol is a uni-directional protocol that only can receive commands and not transmit values such as focus, zoom etc. It would be nice if it were a real bi-directional protocol, then an E-engineer could easily make all kinds of gadgets for us. Is this the reason why the available Lanc products are fairly limited in control? The Console works over FW and I guess have much better protocol support.
I'm going to order the VariZoom Pro control - that will be interesting to work with as I need to control the A1 from a distance.
Old August 15th, 2007, 05:05 PM   #11
Contributor
You can go into the menu and change the focus speed of the ring. But, as you say, it's still way too fast at wide angles.
Old August 16th, 2007, 09:06 AM   #12
Or maybe a firmware update for the A1? (Not that I am optimistic about that possibility).
Do let us know how you get on with the Varizoom. It is good to get feedback from a user with the same camera.
Richard
Old August 16th, 2007, 02:58 PM   #13
Richard
Richard, sure will. I'm ordering it this or next week.
OT: it says "You may not post attachments" - how do one add images to posts?
Old August 17th, 2007, 04:15 AM   #14
You just need to remain an active forum member a while longer, and then MAY NOT will change to MAY. (Don't know the exact time this takes though.)
Richard
