Remaining recording time and memory usage, is this normal? at DVinfo.net
Old July 27th, 2013, 01:47 AM   #1
I just noticed something strange with my XF300 and wonder is this is normal, or some firmware error.
I have a 32 GB CF card in the camera. The camera indicates only 2 minutes of recording time left on this card. So, one would think the card is pretty full, right?
Well, it is not. See the picture below. Only 22.9 GB used and 6.86 GB free. Why does the camera indicate only 2 minutes remaining recording time? IMO it should be much more.
Any thoughts on this?
Old July 27th, 2013, 12:15 PM   #2
Re: Remaining recording time and memory usage, is this normal?
If you are recording at 50MBPS at 1080P, your full recording time should be around 80 mins...How much have you recorded so far?
Josh Morgan is offline   Reply With Quote
Old July 27th, 2013, 01:37 PM   #3
1:02 when it switches to the next card, so 62 minutes and the free space on the card is still 6.21 GB.
Recording at 1080i/25 fps 50 MB/s.
Old July 27th, 2013, 11:49 PM   #4
What CF card are you using? Canon recommends specific brands to be used with this camera...
Old July 28th, 2013, 12:18 AM   #5
SanDisk Extreme 32 GB
Old July 28th, 2013, 11:45 AM   #6
Try to record until the camera stops the recording...Then see how much space is left on the card.
Old July 28th, 2013, 12:32 PM   #7
After it says END, there is still 6.21 GB free.
Old July 28th, 2013, 11:04 PM   #8
Reformat the card and record till full again and see if it actually fills up. I would say that is not normal - but I've never check to see how much space I have on a card... only how much time.
Harry Pallenberg is offline   Reply With Quote
Old July 29th, 2013, 02:40 AM   #9
I see similar issues on the XF100 sometimes. (Sandisk 32GB)
I have also seen 32GB Sandisk cards formatted in the Canon C300 and when they are formatted only 8GB can be used on the card. The Sandisk card somewhat "offended" the C300 since it formatted correctly in a Canon 5DMKIII.
So there seems to be something with the Canon cameras internal software that does this. Are you on the latest firmware for the camera?
/Roger
Roger Averdahl is offline   Reply With Quote
Old July 29th, 2013, 03:00 PM   #10
I have seen this also with the xf100 and 32 gig Transcend cards.
ACE Premiere Pro CC
Adobe Community Professional
Old July 30th, 2013, 02:41 AM   #11
I just updated the firmware to version 1.04. I had 1.02 up to now.
I will initialize a new card and see where it leaves me. I'll let you know.
Old August 1st, 2013, 07:38 AM   #12
I have a problem with one of my 16gb Lexar Professional 300X cards. It records in 4.7 gb sections, which do not join up properly on a long production (stage play or wedding service) Also the Stereo tracks jump from Audio 1&2 track to Audio 3&4 track on a Premiere time line. Have given up with this card, unless I am shooting very short sequences.
Old August 8th, 2013, 04:40 AM   #13
So the question is, How often should you initialize a CF card? Once when you first install it, after every download, once a week? Bob
Old August 8th, 2013, 11:24 PM   #14
Old Boot
After material is backed-up in 2 separate places, I initialize after every shoot. I have the firmware previous to this last XLR User Manual "description" compliance.
Grazie
Graham Bernard is offline   Reply
