XF300 footage: Advice on importing the MXF files with incomplete card structure at DVinfo.net
Old December 22nd, 2012, 08:41 AM   #1
I have several files in their own folders (AB1001, AB1002, etc., etc.) but no longer have the ORINAL full file structure of the card (that is, I don't have the "Journal" or CLIPS001 folder.
Is there a way to trick FCP into seeing the files in Log and Transfer or do I need to purchase an MXF converter to Quicktime?
Thank you!
Event Videography, New England
www.timothybakland.com
Tim Bakland is offline   Reply With Quote
Old December 22nd, 2012, 08:54 PM   #2
Re: XF300 footage: Advice on importing the MXF files with incomplete card structure
Tim I use Premiere Pro, but I have seen reference to an FCP plug-in for MXF files. I have no idea how it works
Canon XF Plugin for Final Cut Pro
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old December 23rd, 2012, 08:57 AM   #3
Yes, no question. I import with FCP all the time (but with whole, intact "CANON XF" folders).
This question pertains to just the individual clip folders within the original (lost) casing folders. (The two original exterior folders, with the "Journal.MIF" file and "CLIPS001" folder no longer exist, and so FCP won't read it.)
Just wondering if there was a fix for that (besides buying an MXF transcoder and doing each MXF file individually).
Old December 23rd, 2012, 04:07 PM   #4
OK Tim, and I thank you for your self restraint at my 'bleeding obvious' comment re the FCP plug-in :-)
Unless I have set a clip prefix, all my Clip folders are named CLIPS001 CLIPS002
The Journal file is always called INDEX.MIF and having just opened a couple in Notepad, they are complex files. There a few threads here that discuss it, but how on earth you are going to fake the INDEX.MIF file I have no idea.
http://www.dvinfo.net/forum/canon-xf...-hdd-copy.html
http://www.dvinfo.net/forum/canon-xf...tion-work.html
