Fur windscreen for XF100? at DVinfo.net
Old April 10th, 2012, 07:35 AM   #1
I was looking for a fur windscreen for the built in mic in the XF100 and B&H has one but over $40, which is ridiculous for just a small windscreen, but they have this one too:
http://www.bhphotovideo.com/c/product/625253-REG/K_Tek_KR_40_60_KR_40_60_Fur_Windsock_for.html
However, I'm not familiar with the Canons XM1, XM2, GL1 and GL2. Would a fur made for these fit fine in the XF100? If not, what others can you recommend for about $20?
Sebastian Alvarez is offline   Reply With Quote
Old April 10th, 2012, 03:11 PM   #2
Re: Fur windscreen for XF100?
This works great. It is $4.99 more than what you wanted to spend.......:)
http://www.bhphotovideo.com/c/product/470272-REG/Rode_DEAD_KITTEN_Dead_Kitten_WindMuff_for.html
Dave Chilson
www.loc.org
David Chilson is offline   Reply With Quote
Old April 10th, 2012, 03:46 PM   #3
Actually I had seen that one, but I find it in really bad taste for them to name it "dead kitten".
I found the solution at home since I had bought a fur for my Sony AX2000 which was actually made for the Panasonic HMC150 but fit very narrowly in the AX2000. Since I will be selling the AX2000 and the built in mic in it is a piece of crap that can barely be called a microphone anyway, I carefully removed the elastic from the fur and now it fits almost custom made for the XF100 :)
Obviously this is removing the holder for the external microphone, which might be a problem in some occasions, such as being in an event where at times you need a directional mono microphone and at times you need a stereo one.
Old April 22nd, 2012, 12:49 PM   #4
"Dead Cat" and "Dead Kitten" are terms used in the business for years....even if in "bad taste".
Michael Fousie is offline   Reply
