xf100 Moire pattern !!! really bad at DVinfo.net
Old August 14th, 2011, 09:26 PM   #1
Just bought a xf100 and put it on auto mode right out of the box to see what i would get out of the camera. When i looked at the footage on the computer the Morie was off the chart, almost unusable footage! anyone else have this problem with this camera. Never thought this would be this big of a problem with this camera. Any sugestions?
Jason Rae is offline   Reply With Quote
Old August 15th, 2011, 06:22 AM   #2
Re: xf100 Moire pattern !!! really bad
Hi Jason,
Are you viewing footage on a PC monitor or HD tv? Try turning the sharpening down to -7 or -8 in the camera. That worked for me, and the resolution is still excellent.
Pat
Pat Reddy is offline   Reply With Quote
Old August 15th, 2011, 09:50 AM   #3
Are you viewing the footage at 100% on your monitor, no scaling? Can you provide a screenshot?
John M. Kim is offline   Reply With Quote
Old August 16th, 2011, 05:01 AM   #4
Yes, I found a moire problem too. Fortunately it is not a frequent phenomenon, which is clearly visible on the display of the camera. In this case, it should be slightly defocus, which is the usual method of solving problems with fine details with moire.
Pavel Sedlak is offline   Reply With Quote
Old August 25th, 2011, 11:49 PM   #5
well i copied a picture profile from here on the forum and all the issues went away. I turned the sharpness down and had no problems. I have shot about 25 hours of footage with no problems except it stops recording at 5:13 secs and starts a new file....
