Evf caps have arrived-get yours now! at DVinfo.net
Old March 23rd, 2011, 11:53 AM   #1
Go Cycle
Canon has just received the XF series EVF caps. The cost is $2.95 each and shipping is $6.95. I would order a few directly from CANON PROFESSIONAL PARTS as they can get lost easy.
The part#: D54-016-000 Phone#1-866-510-1335
Here is what I did: There is a very small hole on the side of the Viewfinder Cap. I took a small elastic hair band and tied the band to the rear shoulder clip located above the output area. I placed a piece of velcro above the output area and a piece of velcro on the outside of the small cap. The cap now swings-off the EVF and I attach same to the velcro. This is a REAL easy piece to lose-real easy. So, now the EVF cap is attached to the body of the camera at all times.
Why the EVF CAP in the first place? Because, there is a DEFECT in the TOP layer of the EVF. Even a small amount of light COULD cause a yellow burn-in on the EVF surface. Canon must know this and has introduced these EVF caps which are really like PLUGS that are placed within the rubber eyecup.
Good luck.....hope you never have a problem like I did-even on a cloudy day and I was aware of the EVF problem from prior posts.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old March 23rd, 2011, 01:12 PM   #2
Re: Evf caps have arrived-get yours now!
Does the burn in problem also apply to the XF100/105 series?
Philip Lipetz is offline   Reply With Quote
Old March 23rd, 2011, 01:33 PM   #3
Could you possibly post a pic of the cap and how it fits the camera?
Andy S
Andy Solaini is offline   Reply With Quote
Old March 23rd, 2011, 05:28 PM   #4
Go Cycle
I placed velcro and a small strap to the EVF plug as well as a bright RED DOT as this is very easy to lose. I placed a small velcro piece to the rear battery door so the EVF cap/plug is out of the way. I also used a small neck card holder and attached the female part to the cap.
See attachments.
Evf caps have arrived-get yours now!-cap-1.jpg   Evf caps have arrived-get yours now!-cap-2.jpg
Lou Bruno
Old March 24th, 2011, 02:13 AM   #5
Hi
Hard to believe: A camcorder sensitive to light! :-o
/Bo
Bo Sundvall is offline   Reply With Quote
Old August 1st, 2011, 08:13 AM   #6
CORRECTION: The part number FOR THE EVF CAP for the 300 and 305 is:
The part#: D54-0160-000
Phone#1-866-481-2569
I was also told they have no protector for the XF-100 so I ended up making my own until I hear otherwise.
Michael Fousie is offline   Reply With Quote
Old August 1st, 2011, 06:00 PM   #7
My wife stitched up a small sock from dark material with elastic which fits snugly over the viewfinder for our XF100. A camera that can't go in the sun, amazing!
Doug Bailey is offline   Reply With Quote
Old August 1st, 2011, 08:03 PM   #8
I use my kids old baby socks on my cameras. And Canon isn't the only brand with this issue. A friend toasted his Panny 170 evf to the cost of about $250. It was exposed for less than a minute to the AZ sun! I then found the thread about all Panny evfs being susceptible.
Robert Turchick is offline   Reply
