Has Anyone Determined 300/305 Rolling Shutter Speed? at DVinfo.net
Old July 28th, 2010, 11:28 PM   #1
When the EX1 came out, we were able to find out the scan speed of the rolling shutter by panning quickly at a constant speed on a perfectly vertical line and looking at two consecutive frames and counting pixels. We concluded that the EX1 scans from top to bottom in 1/60 second (compared to RED's 1/72 second at that time).
Has anyone done this with the 300/305?
If not, is there anyone who can do this test? If anyone can post or send two consecutive frames of a quick, steady pan on a vertical line, I can count the pixels. Narrow shutter is preferable at 23.976 or 24p.
I am looking to find out if the Canon is fast enough to use for animation reference and visual effects plates that would roughly temporally match a (global shutter) Sony F35.
Anything faster than 1/120 second would probably be in-spec for me.
Thanks.
Eric Pascarelli is offline   Reply With Quote
Old July 29th, 2010, 01:19 AM   #2
It's about the same speed or possibly just a fraction slower than an EX1R. Skew tests I did side by side with an EX1R produced very similar results.
Old July 29th, 2010, 01:36 AM   #3
Thanks Alister.
Do you (or does anyone) know how the EX1R compares to the original EX1? Same or faster?
Thanks.
Old July 29th, 2010, 03:34 PM   #4
Same for both cameras.
Old July 29th, 2010, 03:46 PM   #5
Thanks.
I'm guessing that the Canons are 1/60 as well then. They would have to be at least that in order to achieve 60fps.
