Vertical filming with XF605 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XC Series UHD Camcorders
All about the Canon XC10 and XC15 4K hybrid stills / video camera.
Old November 20th, 2023, 10:33 AM   #1
I recently upgraded to the XF605. I installed the latest firmware update. Can anyone tell me how to do vertical filming? I have read that the 605 is capable of filming in vertical. I did find how to rotate the LED screen for vertical filming. However, I just can't seem to find any place in the menus to set the camcorder to vertical. Thank you, Bob
Old November 26th, 2023, 04:46 PM   #2
Re: Vertical filming with XF605
I figured it out. I had to switch from XF-AVC to MP4, film in vertical, then DaVinci rotates it too vertical automatically.
Old November 26th, 2023, 08:56 PM   #3
Equal Opportunity Offender
I was going to suggest turning the camera on its side 90 degrees, but I had a feeling it wouldn't be appreciated. :-)
Andrew
Old November 28th, 2023, 06:01 AM   #4
Well coming from "Downunder", you may have been right. Haaaa.
Bob Safay is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XC Series UHD Camcorders
