XC10 or XC15 - internal vs external (10-bit?) recording at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XC Series UHD Camcorders
All about the Canon XC10 and XC15 4K hybrid stills / video camera.
Old November 26th, 2016, 12:50 PM   #1
As I understand it, the XC10 will output 10-bit from its HDMI. Has anyone compared internal 8-bit to external 10-bit recording?
Thanks.
Steve Kimmel is offline   Reply With Quote
Old November 27th, 2016, 11:40 AM   #2
Re: XC10 or XC15 - internal vs external (10-bit?) recording
It does not output 10-bit.
Old November 27th, 2016, 12:07 PM   #3
Oh, didn't realize. I head read several posts where Canon had stated it did, but probably wrong?
Old November 27th, 2016, 12:08 PM   #4
Which posts were these?
Old November 27th, 2016, 12:51 PM   #5
I'll search for them. While I'm looking: do you have the XC10 that you can test this with?
Old November 27th, 2016, 12:53 PM   #6
I could do this Tuesday, but what kind of tests would be needed exactly?
Old November 29th, 2016, 04:42 PM   #7
Here is what I saw about 10-bit:
Canon XC10 extensive camera REVIEW
https://www.cinema5d.com/canon-xc10-...era-announced/
But... on another forum, someone showed a screenshot that shows only 8-bit output.
So, Gary, if you connect up to a shogun etc., looks like it it's only 8-bit. Can you confirm?
Old November 29th, 2016, 05:40 PM   #8
Neither Gadgetflux or Cinema5D are what I would call authorities on the topic.
How would I confirm if the signal is 8-bit on a Shogun?
Old November 29th, 2016, 06:42 PM   #9
I agree. That is why I questioned whether it's 10-bit or not.
I think that some external recorders will tell you whether it is receiving 10-bit or 8-bit, no?
Old November 29th, 2016, 06:43 PM   #10
The Shogun does not.
Old November 29th, 2016, 06:50 PM   #11
Thanks Gary.
Old January 14th, 2017, 06:31 AM   #12
So... Does it have EXTERNAL 4k 10bit 422 output in the end or not?
B&H says 8bit (here in SPECS https://www.bhphotovideo.com/c/produ...c013_xc10.html)
I couldn't find any official 10bit statement, allthough Canon says that XC15 gives an image like C300 MII (that is 10bit).
Marcello Mazzilli is offline   Reply With Quote
Old January 14th, 2017, 09:00 AM   #13
The image is similar in color, even the "Production Camera" color profile is included (i.e. the Alexa profile). You're reading far too much into that statement to believe Canon means it is 10-bit. The image from the XCS15 is and always will be 8-bit.
Old January 14th, 2017, 12:30 PM   #14
Thanks Gary also for the answers in the other pages
Old January 14th, 2017, 12:36 PM   #15
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XC Series UHD Camcorders
