Thread Tools
Search this Thread
Recording bitrate is there a definitive answer?
My Canon HF G30, set to MP4 mode, will record 25p at (up to) 24mbps and 50p at 35mbps, the 35mbps bitrate is not separately user selectable. I have no regular use for 50p, so normally shoot 25p. The question is, if I shoot 50p for the higher bitrate, do I lose some of the original bitrate by converting the footage to 25p in post? I have seen several opinions, but I am hoping someone will know.
Failing that, is there any way I can find out for myself? Somehow the logical 35/2 = 17.5 seems too simple. |
Re: Recording bitrate is there a definitive answer?
Convert a file, then check its video bit rate. MediaInfo is a free program for that sort of thing.
https://mediaarea.net/en/MediaInfo |
Thanks, but if it was that easy I would have done it. Every transcoder/converter I have used requires the output bitrate to be set, somehow defeating the object. Mediainfo does not convert, only gives the info. I use it often.
Don't convert, just put your 50p files in a 25p project, I do that all the time.
#5 |
Dave, I suspect that's about the quality of the advice you're going to get. If you're delivering 25p from 50p at a CBR it's that simple. If you're delivering 25i (or as the marketers now call it, 50i) you get better quality capturing 50p at 35Mbps. Summary, for best quality per progressive frame and more latitude in post, shoot 25p 24Mbps and 50p 35Mbps for BluRay. If you're not worried about post and aiming at Youtube, that only recommends 8Mbps uploads at 1080p so 17Mbps is more than adequate.
#6 |
What's wrong with my advice Rainer? Dave wanted to know if he shot 50p for the higher bitrate would he lose some of the original bitrate by converting the footage to 25p in post?
That's why I said not to convert and just place the 50p file in a 25 project because in that way you don't loose the original bitrate. |
#7 |
Equal Opportunity Offender
I'd be inclined to go with what Noa says as it will not only reduce handling steps but also the opportunities for generational loss due to re-encoding. Keep it simple.
Andrew |
#8 |
I also agree with Noa, I often use a variety of bitrates from different cameras, and just import the different clips into the project .
Roger |
#9 | |
Noa, it goes against the grain a bit because I have always used an intermediate codec for editing, but I have seen your work and the quality is outstanding, so maybe I should follow your example. I'll certainly give it a go! Thanks. Last edited by Dave Baker; October 23rd, 2017 at 01:00 AM. Reason: remove a duplicate word |
#10 |
You will loose bitrate if you render it out to a low bit rate file but if you place the native file on your timeline nothing changes that file, the change occurs once you render it out, you will loose half of the frames if you render a 50p file out in a 25p project but the bitrate is something you can set yourself when you render the file.
#11 |
Thanks Noa, I would render it as ProRes Normal, target bitrate 147mbps, so no loss there. I do have some 50p footage, so I am about to test your method, I shall try it with some 25p as well.
As I said in my original post, I normally don't shoot 50p, but it's good to know that if I do I can keep the higher bitrate. |
#12 |
Isn't image quality what you really care about? If that's the case, you should do the timeline conversion and render at a given bit rate and compare the image quality visually to a straight up 25P recording, rendered with the same settings. Maybe so some color correction or other effects to stress it a bit.
#13 |
Why do you not normally shoot 50p? Is it because of the look of the footage at 50p? Shooting 50p and then dropping in a 25p timeline will keep the overall look, just not as smooth with the motion.
#14 | ||
#15 | |
You can calculate the bits per frame which, if you decimate every other frame in the video, becomes a total of half the amount. |
