Recommendations for ext mike for XA30? at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old October 2nd, 2017, 12:21 PM   #1
I have a Sony shotgun Mike that I love; but it is only 20mm diameter, too small for the space in the ext mike holder on the XA30.
David Stembridge is offline   Reply With Quote
Old October 2nd, 2017, 03:14 PM   #2
Re: Recommendations for ext mike for XA30?
Buy some O rings and slip them around the mic.
Ed Roo is offline   Reply With Quote
Old October 2nd, 2017, 04:57 PM   #3
I'm using an AT875 short shotgun with an XA20, and am satisfied with it for shotgun mic purposes. It has a 21 mm barrel and came with a pair of roughly 20x3.5 mm O-rings.
You can find O-rings in a variety of sizes at most auto parts stores. For example, Advance Auto Parts sells a 5-pack of 20x3 mm for under $2.
I've also wrapped turns of gaffer's tape around a mic barrel to make it fit.
Double check your mic exact diameter to be sure you get the right size O-rings for your application.
dpalomaki@dspalomaki.com
Old October 3rd, 2017, 02:41 PM   #4
Thanks guys!
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
