HF G40 question - Page 4 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old June 24th, 2018, 02:33 PM   #46
Re: HF G40 question
Originally Posted by Dave Baker View Post
The other thing to note is, CM restricts fps to 25 (presumably 24 your side of the pond), so over and undercrank and 35mbps can't be used.
No Dave, on the Vixia models the full range of frame rates available in Normal (Standard) mode are also available in Cinema Mode, namely:
AVCHD: 23.98p, 29.97PF, 59.94i, and 59.94p (when 28Mbps selected)
MP4: 23.98p, 29.97p and 59.94p (when 35Mbps selected)
I'm surprised you can't shoot Cinema Mode in 50p on the Legria HFG30/40's
Bryan Worsley is offline   Reply With Quote
Old June 24th, 2018, 11:18 PM   #47
Re: HF G40 question
Really? Not that I have tried, the manual is pretty clear.
Dave Baker is offline   Reply With Quote
Old June 25th, 2018, 10:25 AM   #48
Re: HF G40 question
Guess I should have double checked...'cos the Manual is right and I'm wrong.
If you select 59.94p (35Mbps) in mp4 format in Standard (Normal) mode and switch to Cinema Mode it changes to 29.97p.
If you select 59.94p (28Mbps) in AVCHD format in Standard (Normal) mode and switch to Cinema Mode it changes to 59.94i.
So no 59.94p in Cinema Mode but you do at least have the options of 23.98p and 29.97p in mp4 format and 23.98p, 29.97PF, 59.94i in AVCHD format.
Shows how much I use Cinema Mode.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
