Canon XA30 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old April 4th, 2017, 02:06 AM   #1
Canon XA30
Looking at the XA30. Seems to be either NTSC or PAL. Is this still relevant for HD? Or is it just the 50 or 60 frames thing? I'm primarily working online. I'm in Oz which is PAL country but there's a $300.00 price difference between the two.
Bill Watson is offline   Reply With Quote
Old April 4th, 2017, 02:18 AM   #2
Re: Canon XA30
More or less. PAL models have 50/25p or i, NTSC have 60/30p or i and 24p. I'm in PAL land too, so I'm not sure whether the NTSC 24p is only for Cinema mode.
Dave Baker is offline   Reply With Quote
Old April 4th, 2017, 06:09 PM   #3
Re: Canon XA30
Still relevant for capture. If you shoot 30fps in PAL land you will get bars moving down your footage under some interior lighting conditions, often enough to be annoying. If you only shoot outside or with battery lights, doesn't matter. On-line display it's not relevant. Shop around for the PAL XA30, it's widely available for under AU$2000.
Rainer Listing is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
