XA10/20 XLR Audio at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old December 16th, 2015, 08:52 AM   #1
XA10/20 XLR Audio
Ran a quick measurement on the XLR audio inputs for clipping.
The MIC setting is OK for input voltages measured at XLR pins 2-3 up to about 8 mV. Above that the preamps saturate and clipping starts. 8 mV is about -42 dBV
The MIC ATT setting adds 20 dB of attenuation, so it is good for a max of about 80 mV before preamp clipping starts. 80 mV is about -22 dBV
Above 80 mV use the line inputs to avoid clipping in the preamps.
The built-in VU metering cannot be counted on to give evidence of input clipping. Use of headphones and good ears may detect it but that cannot be counted upon.
Note that the voltage at the input pins will depend in part on the source output impedance. Most mics are rated for their open circuit output at 1 PA (94 dB SPL) and output impedance. This can be used as a guide to predicting output to the camcorder if you know something about the venue sound levels.
dpalomaki@dspalomaki.com
Old December 18th, 2015, 08:56 AM   #2
Re: XA10/20 XLR Audio
Thanks for the detailed testing. I've been pleased with my audio results from the XA10 and the XA20 using a wide variety of sound sources.
Jay Massengill is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
