When will we see update to XA-20? at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old January 9th, 2015, 06:40 PM   #1
Any thoughts or ideas?
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old January 10th, 2015, 02:47 AM   #2
Re: When will we see update to XA-20?
So far I have seen version v1030, followed by v1040.
Jo Ouwejan is offline   Reply With Quote
Old January 10th, 2015, 07:57 AM   #3
If by update you mean a replacement model (e.g., a notional XA30), perhaps after it has been on the market for around three years based on past history with other Canon prosumer/profesional market models.
dpalomaki@dspalomaki.com
Old January 11th, 2015, 09:11 PM   #4
The XA10/G10 were announced at CES 2011
The G20 was announced at CES 2013 (this was a modest variant of the G10)
The XA20/25/G30 were announced at NAB 2013
The XF200/205 were announced at NAB 2014 (these were repackaged versions of the XA20/25 into XF style bodies)
Nothing was announced at CES 2015
They are doing updates on the current series in roughly 2 year intervals, which means that we should see new cameras in 2015. Since they didn't appear at CES, we will probably see them at NAB.
Steven Ansell is offline   Reply With Quote
Old January 12th, 2015, 05:56 PM   #5
Quite probably, never. Any upgrade beyond a 1/3 chip, 1080p, 20X, AVCHD/MP4 would most likely put it into the category of a different model altogether.
Rainer Listing is offline   Reply With Quote
Old January 13th, 2015, 10:21 AM   #6
Prior to the XA series, the low end professional cameras were the XHs. That line ended and split into the XF and XA cameras. The original Canon prosumer cameras were the S series. The S10 was released in early 2009, the S20 in early 2010, and the S30 at CES in 2011, at the same time as the G10. Then that line ended.
All things considered, there should be a prosumer/low end professional camera (and variants) released sometime this year, and NAB would be the most likely time I think.
It would have to include a 4K option otherwise there is little point. They could retain most of the body forms of the current cameras by using a 1/2.3 sensor like the ones in this years Sony and Panasonic consumer cameras. That would allow them to use the current lenses for example, which no doubt is a significant chunk of the development cost. They would need a new Digic processor however, since the DV4 only has HD capability. So there would have to be a DV5 before 4K would be possible in that sort of body form.
In other words all they would really need is a new sensor and a new processor. Everything else could remain more or less the same.
Old January 13th, 2015, 10:34 AM   #7
As to Canon's prosumer/professional line, don't forget:
L1 - L2 (Hi-8)
GL1 - GL2
XL1 - XL1s
XL2
XL-H1
The L2 and GL2 had longer then most lives before dropped from the line.
Old January 13th, 2015, 10:55 AM   #8
Also, if Canon starts to move down the 4K camcorder road, it'll have a brand new nomenclature.
Old November 15th, 2015, 08:54 AM   #9
And the answer is available in December 2015!
Old November 20th, 2015, 08:31 AM   #10
i would hardly call them an "update" however. More a rename and re-market. O_o
Welcome... to the real world!
Daymon Hoffman is offline   Reply With Quote
Old November 22nd, 2015, 07:09 AM   #11
More like an incremental improvement, akin to going from the XL1 to the XL1S perhaps? The main thing appears to be the sensor and some additional recording modes.
Don Palomaki is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
