Those Fiddly Little Buttons at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old July 7th, 2014, 04:20 PM   #1
Anyone have any idea so i can make the protrude a bit more especially the one where the front wheel is was thinking about a bit of rubber from end of pencil glued on
Terry Dennis is offline   Reply With Quote
Old July 7th, 2014, 06:49 PM   #2
Re: Those Fiddly Little Buttons
Maybe trim to size some of the self-sticking rubber feet/bumpers you can buy at a hardware store for furniture or cabinet doors. Consider doing something you can undo readily when you sell the camcorder, or decide you are hitting the button by accident too often.
dpalomaki@dspalomaki.com
Old October 26th, 2014, 06:04 AM   #3
I solved my button problem by using a paper hole punch to cut out some small pieces of sticky velcro
Colin Leonard is offline   Reply With Quote
Old October 26th, 2014, 01:37 PM   #4
is that one of those things to put a4 paper in a file folder makes 2 holes
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
