AX 20 spotlight mode and exposure control at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old November 30th, 2013, 02:45 PM   #1
Trying to determine whether an AX 20 is going to be sufficient for theatre and dance events with spotlights.
Can someone tell me how this works? I've never used a spotlight mode before. And when I say how it works I mean, can you assign it to a button? If so ... can this be used both in Shutter Priority mode or full manual?
I'm off to check out some videos on youtube about the camera, but one other question ... does the 20 use a wheel at the back to control the iris or is it located somewhere else?
Scott Brooks is offline   Reply With Quote
Old December 2nd, 2013, 11:47 AM   #2
Re: AX 20 spotlight mode and exposure control
Spotlight mode is one of several available programmed automatic exposure modes, and would not apply in manual mode and probably not in Av or Tv modes either.
The custom dial is at the lower front of the camcorder on the left side. See page 96 of the user manual.
Assignable buttons are described on pager 97.
dpalomaki@dspalomaki.com
Old December 2nd, 2013, 02:27 PM   #3
Thanks Don. I'll download the manual this afternoon.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
