Field of view at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old September 22nd, 2013, 09:58 AM   #1
Field of view
Did a quick test of the field of view at max wide of three camcorders:
(Field width in inches on a yardstick placed about 28.5" from the lens front element.)
These are relative numbers, and your results will vary depending on the overscan of your viewing system.
A large number means wider view.
XH A1 - 35.5
XA10 - 36
XA20 (Dynamic IS) 37
XA20 (Std IS) 39
The XA20 is a bit wider - nice to have.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
