FP24 and 24F at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old July 13th, 2013, 11:17 AM   #1
FP24 and 24F
Canon's documentation for my HF-S200 on the difference between these two purportedly progressive frame settings is sketchy. I recorded some footage on FP24, brought it into Vegas Studio Platinum 12, and set "None" for field interlacing in the project settings. When I played the footage (computer monitor), rapidly moving objects broke up into horizontal lines. After setting "upper field first" in the project settings, the video plays without this artifact.
Can someone explain to me
1. what the difference between Canon's two settings is, and
2. why I would need to set an interlacing in my editor
Thanks.
Philip Ulanowsky is offline   Reply With Quote
Old July 13th, 2013, 01:22 PM   #2
Re: FP24 and 24F
24PF mode records the 24 frames with pulldown into a 60i signal. So essentially, 24PF mode is a 60i video file with the look of 24p.
24P mode records a native 24 frame, progressive file, without any interlacing. In my experience this is the more useful mode when editing footage on a computer, and should theoretically be better in quality.
Check out page 162 in the manual.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old July 14th, 2013, 02:01 PM   #3
Re: FP24 and 24F
Thanks, that clears it up.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
