XA-20 is a fine camera - Page 9 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old February 20th, 2014, 08:56 AM   #121
Go Cycle
Re: XA-20 is a fine camera
You can adjust the iris while recording using the front custom button. I do this all the time in conjunction with the Zebra stripes.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old February 20th, 2014, 09:13 AM   #122
Originally Posted by Sie Callebs View Post
I see a review of the XA20 on the B&H web site in which the customer states that the exposure can't be adjusted while recording:
I don't have the XA20 but that can't be true.....I hope.
Anthony McErlean is offline   Reply With Quote
Old February 20th, 2014, 01:19 PM   #123
Probably got Exposure Lock on.
Paul Inglis is offline   Reply With Quote
Old February 20th, 2014, 05:17 PM   #124
In manual mode, you can adjust iris (or shutter or gain) while recording with the front custom dial if you setup the dial to control exposure. See page 96 of the manual.
dpalomaki@dspalomaki.com
Old April 8th, 2014, 11:26 AM   #125
Originally Posted by Derek Craig View Post
I got to play with the XA20 today. Sweet camera. I'm going to like this over my HV30 and XH-A1…….]
just wondered where you got the vertical hot shoe as noted in this picture below? also, what mic is that?
IMG_20130803_140808_993_20130803143433012_zps47f74dfd.jpg Photo by decraig2000 | Photobucket
i only use mics with AA powering (only wanna stock one support battery for dslr's and video camcorders.
getting an xa20 this week or next. any thoughts as to when there might be an xa30 ?? and/or price ?
"Two wrongs don't make a right, but three lefts do."
Rodger Smith is offline   Reply With Quote
Old April 8th, 2014, 12:51 PM   #126
If past history is any indication, the XA20 replacement might be expected around three years after release of the XA20, but that is pure speculation. Consider for example that the GL2 was not replaced (unless you consider the XH-A1 to have been its replacement). The announcement will typically be well in advance of the availability date to allow for purchase planning.
Price is anyone's guess, but history indicates that it will be generally in line with the XA20 price point adjusted for inflation and market place conditions.
Only Canon knows and they are not saying (unless something is being leaked or announced at NAB).
Bottom line is buy it when you need it but be sure to allow for time learning curve befoer a money shoot.
Old September 1st, 2014, 11:52 AM   #127
Thank you all for a great Post that I have been following for a while, I ordered the Camera will test it before I buy the 2nd one. I am still worried about one posy about the issue with photographer flashes since I am part time wedding Videographer. Thank you all
Khalil Ismail is offline   Reply With Quote
Old September 17th, 2014, 01:21 PM   #128
The Flash Issue has been fixed with the new firmware update it looks like from my test.
Old September 19th, 2014, 11:49 AM   #129
Khalil,
I presume you are referring to the updated Firmware Version 1.0.4.0, which was issued on 17th April 2014 ?
Stephen Dey is offline   Reply With Quote
Old September 28th, 2014, 05:48 PM   #130
Yes Stephen,that what hold me back from buying the camera till now since I do wedding .
Old September 29th, 2014, 01:29 PM   #131
Sorry for the long delay as I just now saw this. The "vertical hot shoe" that you are referring to is not really a hot shoe. It is simply a piece of aluminum plate that I fabricated. Just plate bent at a right angle and then holes drilled to match the wireless mic's mounting holes. I drilled a couple holes in the Rode mic holder and bolted the aluminum plate to the under side using simple machine screws. Just a little home brew ingenuity is all.
Derek Craig is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
